bike stalled approaching stop sign, almost crashed!
Started by adduncan101, September 26, 2011, 06:42:46 AM
adduncan101
Well not very helpfull pics but..... I have also got a HD. Never had any issue with it. This stall thing happend at least one other time I can remember. I was coming to a sign downshifting and applying the brakes apropriatly. The ECU suggestion makes sense.
I had the tank replaced do to warping by the way.
----DC NATIVE----2010 M1100s, 2004 HD Sportster1200, 2001 VW GTI VR6
derby
Quote from: adduncan101 on September 26, 2011, 02:12:54 PM
i think i see a pattern here.
are you relying on engine braking to help slow down the bike? if so, stop. if not, quit downshifting until you're stopped.
-- derby
'07 Suz GSX-R750
Greg
Quote from: derby on September 26, 2011, 02:29:44 PM
You're saying that to stop you pull in the clutch, apply brakes, come to a halt and then click down a bunch of gears? Guess I've been doing it wrong all these years. It's fun to down shift and slow the bike with the engine, especially with clutchless down shifts.
2012 M1100 Evo with Termis
derby
Quote from: SA_S2R on September 26, 2011, 03:29:05 PM
no, that's not how i do it.
while it may be "fun," it's certainly not necessary and it add's complexity to situation where simplicity may resolve the issue entirely.
fwiw, even when i downshift heading for a stop, i'm pretty sure i don't shift down into first unless i've stopped.
Quote from: adduncan101 on September 26, 2011, 01:57:15 PM
I was not leaning over much and probably in second going into first when she cut out.
and even if it was a stoplight vs a stop sign, i'm pretty sure his m1100 would pull away just fine in 2nd gear should the light change before he got fully stopped.
-- derby
'07 Suz GSX-R750
You should downshift and be in the correct gear prior to the corner and then throttle smoothly through the corner
even up to this stop you throttle and slowly bring the bike out of the lean then hit the brakes and clutch as you come to a stop
Shouldn't be braking with the bike leaned
shouldn't be downshifting in a corner
My old VTR1000 used to stall sometimes at slow speed. I almost crashed it once or twice but then I got used to the unexpected stall. These were always parking lot, stop sign, driveway type events. Is this happening to you at speeds faster than 4 MPH?
Oh BTW the VTR had carbs and it was a sticking slide, intake pulse issue. The throttle slides would bounce up and down a bit with each cycle of the engine and once in a while one of them would stick open a bit and stall the engine at or near idle.
It was kind of neat to watch with the airbox lid off. I don't recall my 750 doing that.
Quote from: Sad Panda on September 26, 2011, 09:45:19 AM
This:
http://www.aerostich.com/bank-angle-sensor.html
- Seriously the Monsters have no such items. Dump it on it's side and it'll keep running
My monster has one on the front fender
adduncan101
The down shift to first was at a slow speed and was not a big issue. As with my cars, and other vehicles (all of which have been manual) I don't typically shift into first until stopped. Regardless, the fact that the everything on the bike shut off momentarely is my major concern and troubleshooting my ultimate goal. Again, thanks for everyones help.  :D
Everything?
What about a bad common ground. Like at the battery.
Check your cables, it could be as simple as that.
adduncan101
Yep, everything. I will check the cables and other potential shorts. Good thinking.
DucNaked
  My 1100s stalled three or four times always on downshifts. Dealer could never replicate my problem. The bike was always at temp when this happened. My thought was it was running to lean in the closed loop portion of the map. I also had a starting issue. Bike would crank and crank and just not even try to start.
  I flashed my ecu and got rid of the o2 sensors and never had either problem again. Regardless of your riding stile the bike shouldn't stall when you pull in the clutch.
But it seems we overlooked his problem of every thing on the bike goes dark and shuts off. This is more than an ECU/stall problem.
booger
LOL exactly. Engine braking has a practical purpose. If your bike is tuned properly it shouldn't stall on a downshift. It's all about the tune. A great many problems are solved with a proper tune.
The only trouble is, you have to solve a great may problems to achieve a proper tune!
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Kev M
Quote from: adduncan101 on September 27, 2011, 06:21:14 AM
EVERYTHING? Do you mean the dash went blank and then came back on with the start-up display? (I assume that display is similar on the M11 as it is on the M696).
Like does it say MONSTER 1100 or something like that when you first turn the key on, before it shows mileage or other data?
If it cycled like that, then yes it sounds like a main ground/power cable.
If it DIDN'T CYCLE (and normally does) then "everything" didn't shut off.
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
adduncan101
#28
Quote from: Kev M on September 28, 2011, 06:38:43 AM
Yes kev m. lost the dash, everything (couldn't see the head or tail lights though)
It went lifeless. On top of that, as i stated in the begining the bike is only a couple months old and has  just over 3500 miles. Next thing I knew the engine fired up and the dash came back. I was for only a second but it was very noticable.
has there been any work on the bike at all? any aftermarket parts installed etc?
