bike stalled approaching stop sign, almost crashed!
Started by adduncan101, September 26, 2011, 06:42:46 AM
Kev M
Well that certainly sounds like a main ground or power cable, or possibly something in the ignition switch circuit.
I've not looked at any electrical schematics on these yet, how are they wired? Is there a main relay?
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
main  relay and fuse is under the tank on the back of the airbox.
but I would look at ground, dash/ecu connectors, etc. since it came back on right away.
Somebody probably forgot to tighten something at the dealership when they put it together. I bet if you start wiggling the main harness the the lights will go out and come back on, and relays will click on and off.
It happens..
And I would check the battery first. It probably looks just fine, but its loose...
adduncan101
----DC NATIVE----2010 M1100s, 2004 HD Sportster1200, 2001 VW GTI VR6
DucHead
Quote from: D Paoli on September 29, 2011, 04:19:16 PM
It happens..
[thumbsup]
