February 20, 2025, 06:35:44 PM
S2R 800 + Ducshop Hyper stacks + PC3 + Emission canister removed
Topic: S2R 800 + Ducshop Hyper stacks + PC3 + Emission canister removed (Read 4324 times)
Ohm3d
September 27, 2011, 07:55:36 PM »
Move pics to come.
small hose from air box now with K&N filter mounted above the oil cooler
Relocated Main fuse and ign coil (coil was on the back side on the airbox)
New big breather location, this was the hose that went to the charcoal canister
Filters in
Last Edit: September 27, 2011, 08:19:22 PM by Ohm3d
Ohm3d
Re: S2R 800 + Ducshop Hyper stacks + PC3 + Emission canister removal
September 27, 2011, 07:56:42 PM »
Here is how the PC3 mounts (as suggested by Dynojet) ((not a fan))
Another look at PC3 and the empty space where the emissions canister was
Last Edit: October 04, 2011, 08:12:46 PM by Ohm3d
Ohm3d
September 27, 2011, 07:57:14 PM »
reserved for more pics
Ohm3d
September 27, 2011, 08:03:45 PM »
Took about 2 hours to do everything.
airbox and emission canister were super easy to remove, I think I spent most of the time putting smaller zipties on and relocating stuff. I didnt cut any of the hoses to the airbox or canister, I just rerouted them, in case I decided to put the stock airbox back in (which I won't)
PC3 takes about 10minutes to install, I dont like their location of it and will be relocating it to under the fuel tank once I get a chance to get the bike on the dyno. again most of the time is spent on routing the wires.
I loaded the 504 pc3 map and it runs a little rich, but not bad. Have to set the cold start a little higher when first starting, but once its warms up (like 2-3 min) it idles perfectly
Riding impression... little less low end, mid range is nice, top end is definitely a lot different, placebo effect maybe, lol, but it "feels" better by a little.. The power comes on differently now so it will take a little getting used to, but still very predictable. The sound is unreal. It is loud.... I took a video, but the audio sucked when I loaded it on the comp, so I'm not gonna bother posting it up. I definitely have to wear ear plugs all the time now.
I will post some more pics when I get a chance
Last Edit: September 27, 2011, 08:16:29 PM by Ohm3d
Heath
Re: S2R 800 + Ducshop Hyper stacks + PC3 + Emission canister removed
September 28, 2011, 04:52:30 AM »
Any plans to have it put on a dyno? Or have a custom map done?
2007 Ducati Monster S4RT
Ohm3d
September 28, 2011, 02:35:19 PM »
i am waiting for my exhaust to come and then it is going for a dyno tune with custom map. If my exhaust actually gets here before it snows will be the deciding factor on when it gets dyno'd
Heath
September 28, 2011, 04:04:38 PM »
What exhaust are you going with?
Ohm3d
September 28, 2011, 04:07:41 PM »
competition werks
EEL
September 28, 2011, 09:48:20 PM »
You mean arrow w/ Competition werkes cans.
Ohm3d
September 29, 2011, 02:44:56 PM »
Indeed, the system is being made right now. Should see it in a few weeks (hopefully)
September 29, 2011, 02:54:27 PM »
I like the look of those velocity stacks. Anything that will help the air make the corner...
Ohm3d
October 04, 2011, 08:15:59 PM »
The ducshop Hyperstack kit is good because it comes with everything you need including the smaller filters, and adapters.
the instructions were for a Hypermotard, but it was still pretty easy to figure out what went where.
Removing the emissions canister was not necessary, but I did it anyway.
