NCR M4
Started by zarn02, October 09, 2011, 12:05:04 PM
zarn02
Quote from: zarn02 on October 10, 2011, 03:18:29 PM
*blinks*
To whom, exactly, is that marketed? ???
+1
Do not want
DucHead
muskrat
*blinks*
how the hell should I know >:(
I don't have that kind of cash.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
i want to know more about the parts on the M4 One Shot (the one with 130+ hp on a 1200cc 2v).   For example, why is the oil cooler shaped that way?   Is the M4 One Shot's power "simply" a combination of the NCR Stroker Crank + Big Pistons/Cylinders, and their Cams/Valves?  It it reworked further?
I like its specs a lot but it would be hard to choose between the M4 / M4 One-Shot and the Pierobon F042 bikes with similar NCR engine bits... I mean, they are all very high priced and should be a bit lacking in comparison to the 1199 when doing a $/bike & hp/lb comparison - the new 1199 is alleged to have highest hp/lb ratio of any production bike ever made, a veritable rocket with steering.  And price-wise, is likely to be a tad less than the M4 One-Shot or a tricked-out Pierobon F042...  If I had several large piles of cash, it would be quite a decision to make...
Quote from: j v on October 11, 2011, 12:18:41 PM
it if it like the other NCR bikes, the crank and rods and pistons are all dynamically balanced, crank is lightened and polished.  they up the stroke as on the other bikes.   then they basicailly dremel out divots in the head to reduce weight -- like 2000 of them.
Quote from: j v on October 11, 2011, 12:48:50 PM
golfball style?
exactly.  i have some close-up pics of that New Blue, it was pretty interesting. Not all roudn divots, some are straight cuts but pretty much the entire head surface was done that way.
here is one, you can see a little around the exhaust port.  It's not as radical as I remembered.
battlecry
I like Celli's Codatronca more.
I guess, if you like batmobiles.
i like the batmobile from 1989 Batman, the best batman movie ever made period end of story.  (recent ones are ok, i guess...)
hillbillypolack
Fantastic.  This is the distilled essence of an air cooled motorcycle.  Lighten the bejesus out of it, and increase performance when possible.  Asphalt & Rubber must have their heads up their a$$es because 'only' 130hp in a sub-300 pound bike would be like riding a nuclear explosion.  Add 100-150lbs as the NCR designer said, and you then have current sportbike weight.
Crazy expensive?  Yes. Tour de force craftsmanship?  Certainly.  But for those of you not knowing who these are marketed towards, I have a local Ducati mechanic who purchased two New Blue NCRs when they were new.  Bought by his customers, sight unseen no questions asked.  I saw #12 or #13, it was outstanding.
I'd expect no less from the new bike.  Love it.
