February 11, 2025, 04:23:24 PM
S2R 800 Modified Exhaust
Topic: S2R 800 Modified Exhaust (Read 3094 times)
Risky Business
October 15, 2011, 07:04:35 AM »
I was hoping someone could provide some insight regarding my S2R 800 modified exhaust.
First a little history:
I was tired of my S2R 800 sounding like a sewing machine so I installed a Marving mid-pipe and also cored the stock cans. (I found the chop / core tutorial on this website to be very helpful.) After I cored the stock cans, I had them powdercoated flat black. I also wrapped the Marving mid-pipe and "S" pipes in black Thermotec Heat Wrap. The final product looks very gritty and sounds very throaty.
I later came across (on Ebay) cross cut exhaust tips that would fit onto my stock "S" pipes, deleting the need for the stock cans. At this point, I would basically be running straight pipes. Would someone be able to provide me some insight as to what has to be performed to the motor to run a set up like this?
I will gladly post pictures if someone would let me know how. Thanks you for any assistanceyou can offer.
lazylightnin717
Re: S2R 800 Modified Exhaust
October 15, 2011, 07:09:05 AM »
First I would apologize to your neighbors and everybody within earshot ahead of time.
Comes a time
Says don't you see
Gotta' make it somehow
Risky Business
October 15, 2011, 07:26:37 AM »
That is good advice. I figured the bike would be twice as loud with straight pipes. The guys I ride with have exhausts that are twice as loud as mine so by that math, I should blend with the pack.
S2R 800 '07
October 15, 2011, 07:28:49 AM »
Your bike is running lean (and hot) in stock form.
This will make it worse, but not much worse than what you already did.
It's when/if you also open the airbox that you need to add fuel by an ECU reflash and/or a Power Commander.
It's going to be very loud, but almost without the Ducati bass - I can't imagine anyone being happy with that noise level.
Of course, if the tips are cheap and can be fitted easily - go ahead and try
Risky Business
October 15, 2011, 07:41:14 AM »
Thanks for the help.
I have no intention on opening the air box. Would I have to do an ECU re-flash with my current set up or if I completely eliminated the cored cans?
The cans are easily removed and the tips are just as easily installed.
Thanks again....
S2R 800 '07
October 15, 2011, 07:51:26 AM »
Quote from: Risky Business on October 15, 2011, 07:41:14 AM
You don't have to, but your engine will run better/smoother and not suffer the consequences of being too warm all the time.
It might not be catastrophical short term, but overheated heads aren't good long term.
This condition will be a little bit worse with the tips instead of the cored cans.
You can get a general idea of how things are working if you check (show us?) the color of the headers and pull the plugs to see how they are looking - any lighter than chocolate brown usually indicate a lean condition.
Risky Business
October 15, 2011, 08:29:55 AM »
If I have my local Ducati dealer perform a re-flash, would it be the same re-flash process regardless of running the tips or the cored exhaust? I would like to interchange between the two if possible (especially if the sound is unbearable)
S2R 800 '07
October 15, 2011, 08:40:35 AM »
Quote from: Risky Business on October 15, 2011, 08:29:55 AM
The reflash is usually (only?) to Ducati Performance (DP) specifications and I believe flexible enough to cover your alternatives, maybe even an open airbox - in which case you'll have about 3 bhp and 8 - 10 Nm more. These numbers require normal back pressure though - probably as in cored cans, maybe not with tips only.
Risky Business
October 15, 2011, 09:11:59 AM »
So I guess my best bet would be to bring it to the dealer and let them have at it.
I really appreciate your help.....
Airborne
Crash n' Burn
Monster S2R 800 - ALL BLACK
October 15, 2011, 01:15:23 PM »
That is NOT like running straight pipes, not at all. Run with the udder only, then run straight pipes, its not the same performance wise or sound wise. I have done both and they cannot be compared.
I have been running udder only for about 3 years. I never reflashed anything. It runs fine, though felt it lost a little bit of torque but that could be my imagination. I've changed/inspected spark plugs and they always look fine. Its not all that loud it sounds like Zards.
here is a shitty video of my bike running udder only
Last Edit: October 15, 2011, 01:21:06 PM by Airborne
jmoth79
October 17, 2011, 08:27:39 AM »
+1
Been running udder only for the last 20K miles....no issues and sounds awesome!
You are not a unique snowflake. You are the same decaying, organic matter as the rest of us.
Risky Business
October 18, 2011, 06:36:42 AM »
I removed the "udder" and replaced it with a Marving mid-pipe. Is running the bike with just the Marving mid-pipe the same as running the bike with just the "udder"?
If I install those tips, the only thing I would be running past the Marving mid-pipe would be the "S" pipes and the tips. Not sure how back pressure comes into effect at this point.
It seems that different riders have different outlooks / experience.....
mikeb
October 18, 2011, 11:44:07 AM »
Quote from: Risky Business on October 18, 2011, 06:36:42 AM
No, running just the mid-pipe is the same thing as running straight pipes. Loud, crappy sound, with no back pressure at all.
Do yourself a favor and run a full system like an Arrow system or something similar. One that is designed to work as a system with proper flow and back pressure. Bike will run and sound much better than some cobbled together straight pipe setup.
corey
'06 Tang/Black S2R800
October 18, 2011, 12:32:31 PM »
to each his own.
i say cobble that shit together and let 'er rip.
