My beloved DM620 with 52K -jumped off trailer
Started by ab, October 16, 2011, 09:32:59 PM
ab
Quote from: muskrat on November 04, 2011, 04:25:03 PM
this is what I was talking about http://dallas.craigslist.org/dal/mcd/2666471192.html
Didn't know anything about this.  Need to research this for sure.
Quote from: ab on November 05, 2011, 05:53:50 PM
Now you know bout it ...
Sorry haven't been able to answer back, but, how's the bike doing?
pm or email me for further converstaion on manual issue ...
ab
Quote from: Moto Mecanica PTY on November 05, 2011, 06:03:23 PM
Bike - haven't touched it yet.  Handle bar seems ok.  It's actually lot better than my other bike which after lowside last year is not aligned right.  Need to replace that first than the monster.
Have started looking for parts in here.  Exhaust can cover - called Remus to c if they have it (just the carbon cover) and am waiting for call back and price.  All in all, still looking for part...
Yep conversion didn't work :-(
hillbillypolack
That's quite a bummer.  It's the worst when you know it's dropped, then trying to gather the bike up and get it home.  Sorry to hear about your misfortune.
But now you understand the importance of proper trailering equipment.  Wheel chock, Canyon Dancers, soft ties and Ancra straps are all minimum equipment for trailering a bike.
Good luck with your bike's recovery and let's hope next spring will see it on the road again.
JBubble
Quote from: Mother on October 18, 2011, 03:28:15 AM
I owe a PIF and I have a set of 620 forks if you need em
Let me or Mother (he's a little slow on going to the post office) know about whether you need the forks and we'll send 'em out.
ab
#36
Quote from: JBubble on November 06, 2011, 10:15:14 PM
Thank you.  My initial untrained eyes tell me that the forks looks good.  Come winter, I will let the pro's give the final verdict about the forks.  I will definitely let you two know and thank you for the offer.  I do appreciate that.
What is a PIF?
Thanks IZ.
ab
Quote from: SwampMonster on October 17, 2011, 09:01:58 PM
That really sux hard. About your exhaust can the guy at Blackdragonexhaust.net might be able to help if all else fails it's worth a try. I almost bought a set of tubes for my cans awhile back so I know he dose that kinda stuff. Good luck.
By the way I have nothing to do with Black Dragon just trying to be helpful.
I've been emailing back and forth with blackdragonexhaust.net.  I am hoping i can get the pipe sleeves from them.  But I have not gotten a phone number from the emailer yet.  Simply said send specs and takes about 3-4 weeks.  This was a great suggestion.  I think this is the solution for me for cheap without having to replace my pipe.  Can't find any other alternative.
Has anyone here dealt with this company ? or any other alternatives?
muskrat
I've heard good things and had my exhaust worked on by them.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
ab
#39
Update
Finally took out the pipe and looks like i got more damage and not just the pipe CF Sleeve.
Still getting some used parts from the forum.  So far i have got ( brake lever, frame slider puck, tank latch, headlight assembly).  Need to get rear-set welded too.
Talking to black exhaust url mentioned in the forum to hopefully fix the pipe.  I may have to send it there and keep my fingers crossed.
url=https://www.flickr.com/photos/35374145@N02/6468929859/][/url]
2011-12-06 - 19-26-19 - remus pipe damage - 92 by ab_duc620M2004, on Flickr
2011-12-06 - 19-26-40 - remus pipe damage - 94 by ab_duc620M2004, on Flickr
2011-12-06 - 19-27-03 - remus pipe damage - 96 by ab_duc620M2004, on Flickr
2011-12-06 - 19-25-32 - remus pipe damage - 89 by ab_duc620M2004, on Flickr
2011-12-06 - 19-26-14 - remus pipe damage - 91 by ab_duc620M2004, on Flickr
rgramjet
How much do they want to fix the slip on vs buying a good condition used set?  $250-$400 seems to be the range for cf low pipes in my experience....
-Sofadriver
lazylightnin717
Comes a time
Says don't you see
Gotta' make it somehow
ab
#42
Quote from: rgramjet on December 08, 2011, 03:29:01 AM
Don't know yet.  Will update when I find out.  The pipe is not a total waste.  If the inner stuff is fine and hopefully few torch and bang type of fix, it should be brought back to life (i hope) and get a new sleeve for it.  If it is way to expensive, then I am screwed   [bang]  God forbid I may have to go back to stock ( which i got rid of when the bike was a mere 100miles )
Quote from: lazylightnin717 on December 08, 2011, 04:11:17 AM
Yeah for real. Those pipes look wanked
Yes, that is what happens in such incidents.   [puke]
rgramjet
Looks like several hours worth of work to fix.  Why not put that $$ towards newer unscathed slip ons?
-Sofadriver
H-2 CHARLIE
    If i could rework and cut down that one pipe i would use it for my SS 750
