February 08, 2025, 05:07:21 PM *
Author Topic: Desmo Times Case Saver  (Read 1422 times)
elgallo73
« on: October 17, 2011, 01:13:22 PM »
I'm using a 15 tooth front sprocket on a 2011 Monster 696 (stock) and installed the "hump" style case saver from Desmo Times.  I've found there is a limited amount of clearance (quite tight) and was curious if anyone else here had installed this item.
Garry
zooom
« Reply #1 on: October 18, 2011, 03:13:23 AM »
never heard of one being installed on a newer generation Monster....but it is a good thing in general...
2010 KTM 990 SM-T
mattc7
« Reply #2 on: October 18, 2011, 03:51:58 AM »
The chain is tightest at the front sprocket, which doesn't expand during normal use. You need almost no clearance for it to work properly. As long as there is no contact, it's fine
Omnipotent Potentate
Personal Pretext
« Reply #3 on: October 18, 2011, 04:30:23 AM »
Plenty of folks have. I've had them on both my monsters. Yes, it's tight, but as mattc7 said, as long as the chain isn't rubbing, it's not an issue.
They are cheap insurance - I've seen photos of Duc cases where the chain has gone with and without that saver. With, it mangled the saver and gave a good scuffing to the case. Without the chain punched a hole into the case you could fit three fingers into- not pretty.
