timing question
Started by mahoneygod, October 17, 2011, 11:05:47 PM
mahoneygod
Maybe a dumb question but when setting the timing I put the bike in sixth rotate the rear tire until my vertical is tdc. I get my belts on timing looks good. Same with the horizontal. I rotate the tire again but can't get a complete revolution. Should I be able to? Is there something I missed?
02 S4-in lots of pieces
01 RC51
The engine should rotate.  Post detailed photos, something is wrong.  Do not attempt to start the engine.
Hope this is a silly question, but you've removed the spark plugs right?
mahoneygod
Plugs are out. I replaced the base gasket and pistons. Checked the squish everything looked good. I'm assuming I just screwed up the timing. I got full rotation before I put the belts on. I'm gonna redo and see what happens. I don't have any way to post pics. Sorry.
01 RC51
Sorry - had to ask. Once in a while we get folks asking such things that have neglected those basic items. But it seems like you're beyond that base level of tech.
I'd look at the vertical as the possible source for your troubles. It's a pain in the ass to line up that cam due to the fact you're pushing on the helper spring when the marks are lined up.
mahoneygod
Yeah i just got it back on and it seems better now. It was late last night and I might have had a few and other random excuses
01 RC51
All of the timing marks are based on the horizontal cylinder being at top dead center.
mahoneygod
Thanks nick I woulda missed that. Thanks for all your help yesterday. Any tips on getting the wiring back in place?
01 RC51
mahoneygod
So i have it all back together again. Tried to start her and no go. Shes turning over but she wont start. SOB
01 RC51
gatorgrizz27
Check for spark, and make sure your intake and exhaust valves are closed (have free play) when each piston is at TDC.
gatorgrizz27
#10
Not sure if this is the same setup as the S4 but it should help
