Brake Caliper Adapters
Started by SwampMonster, October 26, 2011, 09:38:19 PM
SwampMonster
I have a 1995 m900 is this the adapter I would need to go to the newer 65mm spaced calipers. I was told they were hard to find that is why I am skeptical. Thanks in advance.
http://www.ebay.com/itm/65mm-Billet-Brake-Adapters-Cagiva-Ducati-Guzzi-Laverda-/270663472599?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item3f04ccd5d7
All the bikes that used the f08 calipers would use the smaller rotors.
I'd go with the yoyodyne pieces.
Quote from: cayman s on October 27, 2011, 07:08:55 AM
They look similar to these from Bevel Heaven:  http://shop.bevelheaven.com/detail.aspx?ID=1466
But note that they are for 280mm diameter rotors
They are both made by GuzziTech.
I know them, that is Ed Milich and they are well done.  I have a pair of his adapters for my Pantah.
Those adapters are NOT for the later 40mm type (5156 caliper) bikes.  Those are for bikes with the F08 two-piston calipers (which were used with 260, 280 and 300mm rotors)
The ones YoYodyne has are correct, but they are Brembo and can be bought from any brembo dealer.
