February 21, 2025, 02:07:23 PM *
Author Topic: Brake Fluid!  (Read 2842 times)
DucsLikeBread
Why not?
« on: October 29, 2011, 12:53:07 PM »
So on my 04 monster 620 the front reservoir it says use Dot 3 then it has a Division symbol 5, the reservoir in the back says use Dot 4. So can I use Dot 4 for all? Or do i need to buy a Dot 3 or 5?  Huh?
Online Online
« Reply #1 on: October 29, 2011, 12:58:09 PM »
DOT 4 is fine.
Castrol makes a fluid that meets both DOT 3 and 4 specs and is very reasonably priced
rgramjet
« Reply #2 on: October 29, 2011, 02:51:48 PM »
Don't let it get on your gauges......
You're obviously a crack smokin' redneck carpenter. Kiss
-Sofadriver
live2ride
monster 750 dark
« Reply #3 on: October 30, 2011, 11:34:35 AM »
do not use dot 5.
use dot 3, dot 4, or dot 5.1.
dot 3 is basically obsolete, and 5.1 is hard to find.  just use 4
« Reply #4 on: October 30, 2011, 11:49:56 AM »
compare brake fluids (4 and 5.1)
http://www.swedishbricks.net/700900FAQ/Brake%20Fluid%20Comparison.htm
Castrol LMA is good for most general street use, but keep in mind all brake fluid boiling point drops.
mookieo2
« Reply #5 on: October 30, 2011, 06:28:11 PM »
Motul rbf 600
Curmudgeon
« Reply #6 on: October 30, 2011, 07:55:18 PM »
GT LMA works as advertised. (LMA = Low Moisture Absorption) Nothing else goes in my English and Italian toys, both 2 and 4-wheeled. The German stuff gets Ate Amber except for Benz which gets their proprietary clear long-life DOT 4.
For racing, both Brembo Sport EVO and Ate Super Blue Racing are available from Tire Rack amazingly!  Cool
Langanobob
« Reply #7 on: October 31, 2011, 04:42:21 PM »
GT LMA works as advertised. (LMA = Low Moisture Absorption)...
Never knew or even thought about what LMA stood for, thanks.  I remember when it was required for British cars since as I recall they evidently had natural rubber brake parts that other brake fluids would attack.  We used to call it Castrol Lima, like Lima Peru.
Bob
Curmudgeon
« Reply #8 on: October 31, 2011, 07:08:22 PM »
Bob
Not sure these days about modern DOT 4+ eating seals, but I know the GT LMA lasts at least 2 years and as long as 5 years and gives a good color indication when it's time for a change. Definitely keeps seals from rotting in cars / bikes which get occasional use. My last life before retiring was 21 years in a 1.200 unit/annum Land Rover Centre and we used nothing else.
Oddly I tried to pick up a pint tonight to bleed the Defender as I had only 1 unopened bottle here and the usual suspects don't carry it. I could swear they did. Will have to check independent parts places or pick some up at the local dealer. Have to stop there anyway as I ordered a case of LR antifreeze for alloy engines in the old vehicles. $2 more than the cheap stuff and has the proper PH and buffers for the "Legacy Vehicles".
GT LMA is easy to find on-line of course.
Regards!
William
« Reply #9 on: October 31, 2011, 07:10:45 PM »
Regards!
William
NAPA carries it in their stores, along with Pentosin.  Advance doesn't and I don't think Auto Zoned does either.  I think Pep Boys has Castrol.
Curmudgeon
« Reply #10 on: October 31, 2011, 07:32:07 PM »
Thanks! I looked at NAPA on-line tonight and it didn't show but I have a NAPA less than a mile from the house in this little town and rarely have they let me down so far. TDB.
« Reply #11 on: October 31, 2011, 07:40:43 PM »
The NAPA near me is a franchise store, so maybe they carry more than the regular NAPAs but they had it.
Online Online
« Reply #12 on: November 01, 2011, 03:23:01 AM »
I get Castrol fluid at a Federated Auto Parts store
« Reply #13 on: November 01, 2011, 05:33:46 AM »
I have also used Valvoline SynPower DOT4, but I have heard it is discontinued.
Dry BP was like 503 and wet BP around 350.
They have a "regular" DOT4 variety but it is crap compare to that.
