Effects of brake fluid on 304 stainless.
Started by Pip, November 04, 2011, 12:08:32 PM
Pip
I'm having a replacement brake caliper piston machined from 304 s/s bar stock for my little '76 CB250, as the stock one is chromed carbon steel and has been eaten by years of brake fluid. My question is, will the 304 have enough corrosion resistance to handle brake fluid for years to come? I got a 1.5inch diameter by 7 inch long chunk for free, and need to make sure it can handle this before I get it machined. I would have preferred 316, but 304 is what I got.
Am I good?
I'm no metallurgist, or rocket scientist, but if chromed steel was good...
I think the stainless will be too.
Langanobob
Brake fluid won't attack 304.  It also won't attack the chrome plated steel in your original piston and what attacked it was water in the brake fluid.  The 304 should hold up well, even with some water contamination but may suffer some slight corrosion with time and water contamination...we all need to occasionally flush our brake and hydraulic clutch systems and replace the old fluid with new.  I'm as guilty of anyone of neglecting brake fluid changes.
Bob
Pip
Thank you both. I'm gonna go ahead and have it machined then. I'll be changing brake fluid alot more often than the PO did, I can assure you.  [thumbsup]
corey
chrome's the key. sturdy stuff.
304 stainless. 3 parts chrome, 0 parts moly, 4 parts nickel... plus the steel of course.
Quote from: corey on November 04, 2011, 01:23:35 PM
...and nickel is pretty corrosion resistant too.
maybe that's why they call it stainless? ;D
Pip
 [cheeky]
Now I'll be digging into metallurgy, to keep from anymore embarrassing newb posts.  ;D
zarn02
Quote from: The Zombie Pip on November 04, 2011, 01:56:44 PM
The DMF: Inspiring Educational Excellence
304 is a beyotch to machine, let us know what the shop says.
Langanobob
Quote from: Speeddog on November 04, 2011, 07:58:23 PM
Speeddog has a good point.  Here's a link to one of many places where you can buy 303 SS, very similar corrosion resistant properties to 304, but I think it has better machining properties:
http://www.speedymetals.com
Not free but relatively cheap for the small amount you need.
teddy037.3
at least it's not inconel
teddy037.3
Quote from: teddy037.3 on November 05, 2011, 10:42:07 AM
pimping me out now, are we?  [cheeky]
Not really...
you just didn't seem scared of a little stainless. ;)
teddy037.3
Quote from: ducpainter on November 05, 2011, 10:45:14 AM
Not really...
well, yeah... but I'd just use my seniority to tell one of the lathe guys to make it for me  [evil]
