January 10, 2025, 05:00:44 PM
Tools for valve adjustment
5
6
Topic: Tools for valve adjustment (Read 22573 times)
lazylightnin717
Re: Tools for valve adjustment
Reply #30 on:
January 23, 2012, 06:56:56 PM »
Night #1
I had a few hours to get started on some stuff tonight. Removing the gas tank consumed most of that time
I had to syphon a good bit of gas out of the tank... my burps taste like premium
The other bit went all over me and the floor... Stupid fuel lines took forever to get off
Not a good start
I'm also pretty pissed at how bad the paint is on the engine cases. It's pathetic and annoys me in the worst way possible.
Comes a time
Says don't you see
Gotta' make it somehow
lazylightnin717
Reply #31 on:
January 24, 2012, 06:32:08 PM »
Night #2
Had even less time tonight but still managed to get some stuff done.
Removed the airbox and battery and all things around it.
Still haven't touched the TBs.
Sure as hell a tight fit to the vertical exhaust valves with the suspension linkage right there.
How do you guys do it?
Comes a time
Says don't you see
DucHead
No garage queens
Reply #32 on:
January 25, 2012, 04:03:02 AM »
Quote from: lazyjinglin717 on January 23, 2012, 06:56:56 PM
... Stupid fuel lines took forever to get off...
Cut both the feed- and return fuel lines and insert brass quick disconnects (I got mine from Omega.com -- a search will turn up the part numbers).
Here they are (metal with shut-off valves on both halves):
FT-LCD170-05: $24 (5/16" ID hose barb, In-line, 2.00" Length, Shutoff, Coupling body 1/4" flow);
FT-LCD220-05: $15 (5/16" ID, Hose barb, Straights, 1.85" LCD Length, Shutoff, Insert 1/4" flow).
Insert the quick disconnects in opposite directions so you don't mix up the two lines.
Last Edit: January 25, 2012, 04:07:57 AM by DucHead
"45"
lazylightnin717
Reply #33 on:
February 01, 2012, 04:39:25 PM »
Who can tell me what this is?
There wasn't a fuel line attached to the rear barber outlet when I removed the tank.
Better yet... does it need a line and where should I run it?
Comes a time
Says don't you see
battlecry
On a silver black phantom bike...
Reply #34 on:
February 01, 2012, 05:27:44 PM »
That is the fuel pressure regulator. The empty port references local atmospheric pressure. No need to connect it anywhere.
lazylightnin717
Reply #35 on:
February 01, 2012, 06:14:09 PM »
Molto bene!
Grazie
Comes a time
Says don't you see
lazylightnin717
Reply #36 on:
February 06, 2012, 05:21:25 PM »
Update
Clearances are as follows.....
Horizontal Intake
LO- .0035 LC- .0065
RO- .005 RC- .006
Horizontal Exhaust
LO- .003 LC- .008
RO- .004 RC- .008
Vertical Intake
LO- .006 LC- .005
RO- .006 RC- .007
Vertical Exhaust
LO- .008 LC- .004
RO- .008 RC- .005
So.... what do you more experienced people say? I was gonna shoot for the LT Snyder specs but I will gladly listen to anyone else's arguments.
LT Specs
Intake
Opener .004
Closer .004
Exhaust
Opener .006
Closer .004
I pulled an opening rocker pin tonight just to get a feel for it. When I put it back in for the night, air got trapped behind it. Is this bad or will it not effect anything? LT Snyder manual says to scribe a line down the pin to allow the air to run out. All is fine and dandy but hot damn I'd have a hard time taking a dye grinder to my rocker pins.
I'm also getting a little anxious now. Bikes been apart for a while and I'm hoping that my pictures will get it back together. Otherwise, I'm going to be posting a lot more pictures and asking a lot more questions.
Comes a time
Says don't you see
Reply #37 on:
February 06, 2012, 06:08:00 PM »
IO .004-.006
EO .006-.007
IC .002-.004
EC .002-.004
Don't worry about the air behind the rocker pin.
lazylightnin717
Reply #38 on:
February 07, 2012, 06:17:00 PM »
A few observations....
Horizontal rocker pin cover on the right side has some gouging. Looks like a closer pin backed it's way out and is doing a number on the plate.
Oh and I seem to have discovered 5 flaking rockers... I'm pretty pissed
Would that have effected my measurements in any way when I was checking my clearances?
I'm so make the beast with two backsing pissed that I have to yank 2 closing rockers. Those springs look like a pregnant dog to get back in with the heads still on the bike.
Ducati
Comes a time
Says don't you see
Reply #39 on:
February 07, 2012, 06:37:56 PM »
Sorry to see your flaking rocker, and hearing it's got partners.
Clearance measurement associated with a flaked rocker is FUBAR.
IE, the opener clearance you measured on the valve with *that* rocker is worthless, other than the practice you got...
Doesn't really matter in the long run, as you'll have to re-do the measurement with the replacement/reconditioned rockers anyway.
Were the flaked closers paired up with flaking openers?
Yes, the springs are a pregnant dog to get back in.
Which closers are you replacing?
If they're intakes, you have to undo the exhaust closer spring on the same side, as it sits on the post inboard.
lazylightnin717
Reply #40 on:
February 07, 2012, 06:44:01 PM »
Vertical exhaust left opener
Vertical exhaust right closer
Horizontal exhaust left opener
Horizontal intake right opener
Horizontal intake right closer
Comes a time
Says don't you see
Reply #41 on:
February 07, 2012, 07:06:08 PM »
Mmmm...vertical exhaust closer.
That one's fun.
Don't despair.
lazylightnin717
Reply #42 on:
February 08, 2012, 04:25:29 AM »
Quote from: Speeddog on February 07, 2012, 07:06:08 PM
That one's fun.
I guess I will see soon enough
Comes a time
Says don't you see
lazylightnin717
Reply #43 on:
February 17, 2012, 04:53:50 PM »
Tomorrow is going to be a good day
Comes a time
Says don't you see
Reply #44 on:
February 17, 2012, 05:39:44 PM »
That green bin full'o'shims will come in handy.
I like the paint brush too.
So.... you pulled the head off.
5
6
