January 10, 2025, 01:50:43 PM *
Pages: 1 ... 3 4 [5] 6   Go Down
Author Topic: Tools for valve adjustment  (Read 22544 times)
lazylightnin717
« Reply #60 on: March 01, 2012, 06:17:24 PM »
Ahhh, a man who understands frustration
There is nothing worse than getting owned by an inanimate piece of rubber
Comes a time
Says don't you see
Gotta' make it somehow
Ddan
Some of my best friends are whores
« Reply #61 on: March 02, 2012, 01:40:39 AM »
Take up golf
 Grin
                    flogged successfully  NHMS  12 customized.  Twice.   T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
lazylightnin717
« Reply #62 on: March 04, 2012, 06:04:14 PM »
Take up golf
 Grin
Golf chafes me off  Tongue
I always slash 'em to the right
Although I can play a pretty mean game of mini-golf  Grin
Comes a time
Says don't you see
ducatigirl100
« Reply #63 on: March 06, 2012, 09:30:20 PM »
In conjunction with Sad Panda's recommendation, if you are put off spending the $65.00 for the crank turning tool, try this:
http://www.motomfg.com/Crank_shaft_turning_tool_for_Ducati_s_p/et-1.htm
Tanks for the  link...just bougth a 100$ worth of tools  Smiley waytogo
lazylightnin717
« Reply #64 on: March 07, 2012, 05:53:07 PM »
I'm taking recommendations on silicone sealant for the base, head, valve gaskets etc... Yay or nay?
If yes, what kind?
Another home job
Comes a time
Says don't you see
« Reply #65 on: March 07, 2012, 06:27:31 PM »
ThreeBond 1194 for the base gasket, AFAIK HondaBond, YamaBond are the same stuff.
Install head gasket dry.
If new, valve cover gaskets, sideplate gaskets install dry.
If used, clean with contact cleaner, and install dry.
lazylightnin717
« Reply #66 on: March 12, 2012, 04:41:01 AM »
Any idea what size set screw I should plan on using to plug the oil galley in the case?
Comes a time
Says don't you see
« Reply #67 on: March 12, 2012, 08:02:28 AM »
I use a 10-24 setscrew, I forget the length, but I've got a bunch at the shop...
A little grease in the drill bit, turn it in by hand.
Grease the tap, do the same.
Only go in far enough for the setscrew to go down flush to the deck.
Clean threaded hole with solvent on Q-Tips.
Use high-heat and oil-resistant loctite.
lazylightnin717
« Reply #68 on: March 13, 2012, 02:56:06 PM »
The most blingin' thing I've ever seen!
Can't wait to get it back to the point where I can install 'em
Comes a time
Says don't you see
zarn02
« Reply #69 on: March 13, 2012, 03:21:20 PM »
Quick-disconnects for bikes that don't have a QD at the tank?
lazylightnin717
« Reply #70 on: March 13, 2012, 03:35:53 PM »
Yes indeed
Removing the tank was a real PITA so I decided to go this route
Comes a time
Says don't you see
lazylightnin717
« Reply #71 on: March 21, 2012, 03:07:06 AM »
Gaskets are at Ferracci. All I gotta do is pick them up.
Yamabond the base gasket on both sides or only one?
As far as the assembly is concerned, here is my plan of attack... Suggestions are welcome
Once the head/jug is off, tap and plug oil galley hole. Install base gasket. Take two wooden dowel rods and place beneath the piston and rotate the engine until the piston sits flush on the dowel rods. I want to do this to facilitate reinstallation of the cylinder. Have a buddy slowly bring the cylinder down as I compress the piston rings by hand and ease it on in.  Once that is done, I'll install the head gasket/head and torque to spec. Then I should be well on my way.
Reattach exhaust...reinstall shims...take measurements...hopefully ride by April
I haven't picked up a ring compressor because people are telling me it can be done by hand very carefully but mostly because I don't know what I'm looking for or how to really use one.
Would you advise against that?
Comes a time
Says don't you see
« Reply #72 on: March 21, 2012, 07:51:53 AM »
Don't try to do the rings by hand.
Get a ring compressor, this is the one I have, it's a Blue Point, and it works great:
lazylightnin717
« Reply #73 on: April 02, 2012, 04:41:43 PM »
Just when I though I was a master mechanic...
I feel my cams dragging  Undecided
What am I missing here?
Horizontal exhaust put back in place with shims that I ordered. Checked the clearances at .004 opener and .003 on the closers.
The cam is dragging hard
Huh?
Comes a time
Says don't you see
« Reply #74 on: April 02, 2012, 05:30:14 PM »
Check for something trapped between the valve and seat.
Or all they all dragging?
Pages: 1 ... 3 4 [5] 6   Go Up
