Removing Baffles out of Termi tips
Started by He Man, November 14, 2011, 10:18:33 PM
one of my baffles is straight up stuck. ive twisted them, lubed them up, and yanked on them with a cable. im short of going into the inner lip of the exhaust tip and polishing it as smooth as a i can and see if that will help slide them out.
any tips/ i feel like im going to break the damn thing.
btw: termis sound so make the beast with two backsing badass!!!! they are much better sounding than arrows in my opinion!
Quote from: He Man on November 14, 2011, 10:18:33 PM
i've had mine stuck. i pulled off the pipes and stuck a broom stick in the other side and used a rubber mallet.
Heath
These are your new ones right? The 45º angled ones?
First make sure the screw is out (duh!! but yeah I speak from experience)
Then pull at the top of the inner part of the baffle then the bottom and go back and forth.  One will give and you will get it out.  Sometimes you can try the left side then the right.
2007 Ducati Monster S4RT
Pedro-bot
just curious really.
with the baffles in, its really not much louder than stock. in fact because the way the  exhaust tip is pointed its quieter than stock when on the road.
and yea the 45 degree ones ill try and post a pic later of how my bike looks like. been scrambling for time lately. :(
if anything id like to drill a few more holes into the baffles to get a bit more grumble out of them.
i really cant believe how much quieter it is compared to my stock exhaust. mine must be broken or something.
Heath
dbran1949
#6
Check this post I put up in '09
http://www.ducatimonsterforum.org/index.php?topic=23487.msg414282#msg414282
you're right the pipes with the baffles in are two quiet, and if you have the full kit with ECU and open air-box the bike runs super rich, you can smell the unburned fuel coming out the pipes. Let me know how you make out with the drilling. I'd like mine a little quieter but not as quiet as with the baffles
