More choices for fluid reservoirs
Started by Nomad, November 17, 2011, 08:15:37 AM
Nomad
Finally some choices out there other than Rizoma.  I have to admit, I still like the look of the Rizomas better, but I know some people out there would like something a little different.
http://spieglerusa.com/brakes/brake-fluid-reservoir.html
zooom
call me weird...I like the white plastic pee cups for visual inspection purposes...
2010 KTM 990 SM-T
thought
Quote from: zooom on November 17, 2011, 09:15:50 AM
i'm with you on that... i'm a bit anal about making sure the brake fluid isnt too dirty and the metal ones make that hard to tell.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
Rigez
Seems to me that the inspection window on the resevoir is sufficient to veiew fluid level and how clean the fluid is.
corey
Quote from: Rigez on November 17, 2011, 12:14:39 PM
Using a piece of clear hose between the reservoir and the master is also a good trick.
OT
#5
Speigler neoprene brake fluid tubing --- $1.20/inch   [roll]
Also, www.dan-moto.com
Looking for haute reservoirs?  Check out what MotoCorse has to offer.
sofadriver
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
thought
Quote from: corey on November 21, 2011, 10:41:59 AM
never thought of that... but then again, right now no plans for changing reservoirs.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
sofadriver
Quote from: OT on November 21, 2011, 04:42:55 PM
a little less pricey.........
http://www.motovationusa.com/mvstore/scripts/prodView.asp?idproduct=1265
BTW, no need for clamps on these hoses. Plastic wire ties work just fine.
For a cool look, use red, white & green ties.  [thumbsup]
Mike in Tacoma
'96 900 SS/SP
IBA 38181
lawbreaker
Quote from: thought on November 17, 2011, 09:23:58 AM
I know clutch fluid discolors... but i've never seen break fluid discolor (get dirty)...
