October 20, 2024, 06:41:16 AM
The power of orange compels you!
68
69
70
71
163
Topic: The power of orange compels you! (Read 478018 times)
Re: The power of orange compels you!
Reply #1020 on:
November 02, 2013, 03:42:30 AM »
690 Duke, 2012 model, 6000 miles.
Got a collapsed cam rocker bearing. Not catastrophic, but causing excessive valve clearance which was audible. Luckily not expensive to replace.
Anyone heard of this?
Omnipotent Potentate
Personal Pretext
Reply #1021 on:
November 02, 2013, 04:58:44 AM »
Let me guess - exhaust side?
There's been troubles with the rockers. An early like 2008 batch had bad bearings. But also it seems that the auto decomp might cause over short bearing life.
Good news is it's an easy DIY job and the part is about $60
Reply #1022 on:
November 02, 2013, 05:08:38 AM »
Thanks SP.
Sounds like the cause.
Rocker and bearing kit is $135 here, not bad.
Personal Pretext
Reply #1023 on:
November 02, 2013, 07:15:33 AM »
Rocker and bearing? The valve rockers come with bearings. Each rocker is about 60 usd. So exhaust and intake would be around your listed price.
Reply #1024 on:
November 02, 2013, 02:12:34 PM »
New kit, rocker with bearing. Thought about bearing replacement, but at that price.
The bike is a nifty little jigger!
The Mad King Pepe'
Reply #1025 on:
November 02, 2013, 03:48:12 PM »
Loving mine more and more! Headed out to Green Ridge State Forest today, 2 hours of slab each way, but absolutely worth it!
This is Bond's Landing on the Potomac River.
The Architect
Reply #1026 on:
November 03, 2013, 04:45:13 AM »
The ST is sold. Now I just need to find a used 690 smc.
http://www.livefreeballistics.com
Personal Pretext
Reply #1027 on:
November 03, 2013, 05:06:05 AM »
Not the easiest task. Keep an eye out for 690 Enduros too. One can fit SMC wheels and brakes to the Enduro, but not vice versa.
The Architect
Reply #1028 on:
November 03, 2013, 05:17:44 AM »
Quote from: Slide Panda on November 03, 2013, 05:06:05 AM
I was not aware of that.
The best kind of whore is a
Reply #1029 on:
November 03, 2013, 06:01:14 AM »
Quote from: The Architect on November 03, 2013, 05:17:44 AM
The smc has a steeper rake so the enduro wheel hits stuff when the fork compresses.
Personal Pretext
Reply #1030 on:
November 03, 2013, 06:22:10 AM »
Also the Enduro has longer forks with an offset axle mount. The SMCs are a bit shorter and the axle is inline like sporty bikes. Shocks different and the triple is too. But 99% of those bikes is identical.
Wheels from the SMC are a direct no fuss swap in the rear. In front you need a caliper relocator *if* you want the full Monty and do the SMC brake too. If not the Enduro rotor just swaps right on
Reply #1031 on:
November 03, 2013, 06:35:59 AM »
Get the brake too.
The Architect
Reply #1032 on:
November 04, 2013, 06:28:55 AM »
What do you guys think of this?
http://www.ebay.com/itm/231087769956?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
zooom
Reply #1033 on:
November 04, 2013, 06:35:18 AM »
Quote from: The Architect on November 04, 2013, 06:28:55 AM
SUHWEEEEET!!!
2010 KTM 990 SM-T
Reply #1034 on:
November 04, 2013, 06:41:36 AM »
What zooom said. That's how much I have into my 450 and sumo conversion.
That's a nice package.
The only thing wrong with it, that I can see, is that its not in your garage.
68
69
70
71
163
