The power of orange compels you!
Started by Monsterlover, November 20, 2011, 06:35:04 PM
MadDuck
Quote from: zooom on October 22, 2013, 07:53:47 AM
StupidDuke 1290R ride review....
http://www.asphaltandrubber.com/reviews/ktm-1290-super-duke-r-review/
It just gets worse.   [evil]  I bet the thing sells for over $20K here and they'll sell every last one of them.
That stock exhaust does look bleh... it's a plot!
Got a question for you Orange People ;D.
Buddy has a 2012 Duke 690, but lost his manual. What is that adjustable, numbered dial under the passenger seat for? ABS, power modes? His is set on 0.
DanTheMan
#993
Quote from: koko64 on October 23, 2013, 09:59:30 PM
Called the map select switch
You want 2  [evil]
0=bad gas
1=limits power, good for rain, dirt low traction situations
2=full power and all the jerkiness that goes with it
3-9= standard normal setting
From the manual
QuoteSwitch off the ignition by turning the ignition key in the position (690 Enduro EU, 690 Enduro AUS/UK)   (690 Enduro USA).
â€"   Remove the seat. (   p. 58)
â€"   Pull the Map‐Select switch and holder  upward off of the retaining bracket.
â€"   Pull the Map‐Select switch out of the holder.
â€"   Turn the adjusting wheel until the desired digit is next to marking .
Set the Map‐Select switch to Soft.
â€"   Set the adjusting wheel to position 1.
Soft â€" reduced homologated peak performance for better driveability.
Set the Map‐Select switch to Advanced.
â€"   Set the adjusting wheel to position 2.
Advanced â€" homologated performance with extremely direct responsive- ness.
Set the Map‐Select switch to Standard.
â€"   Set the adjusting wheel to position 3, 4, 5, 6, 7, 8 or 9.
Standard â€" homologated performance with balanced responsiveness.
Set the Map‐Select switch to poor fuel quality.
â€"   Set the adjusting wheel to position 0. Poor fuel quality
â€" homologated performance is reduced in accordance with
the fuel quality, use for no more than 1 tank of fuel
â€"   Position the Map‐Select switch in the holder.
â€"   Slide the Map‐Select switch with the holder downward onto the retaining bracket.
â€"   Mount the seat. (   p. 58)
http://www.ktmforums.com/forums/duke/170-690-duke-map-select-switch.html
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 M630ie Dark - Sold
2003 CRF175F
1996 Honda CR125R - Sold
Thanks Dan [thumbsup].
Think I got it.
0= Bad fuel
1= Wussies
2= Hooligans
3= Normal
;D
DanTheMan
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 CRF175F
The KTM manuals in PDF form are online from KTM - he can just download a copy.
Hell, I've got a copy on my phone.
DanTheMan
Talking to Superplush suspension never ends well for my wallet. New shock collar, new springs and possible re-valve for my SMC>Enduro conversion project.
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 CRF175F
Money spent on suspension is never money misspent.
Test rode the "Duke 125" . . . :o hard to believe it's a 125 !!!
Might have lowest grade Brembo components but, they do a pretty good job . . . but, $4800 ???
DanTheMan
Quote from: Monsterlover on October 24, 2013, 05:21:08 PM
Well its a lot of "never money misspent" money  [laugh]
But i will have a SMC and Better than Enduro spec 690 with custom tuned forks for each. 17" wheels for on road and 21/18" off.
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 CRF175F
