Alternative to electric motorcycle runs on thin air
Started by Two dogs, November 30, 2011, 01:59:47 PM
Two dogs
 [thumbsup] [Dolph] [thumbsup]
Zero emissions no end of life battery disposal issues = win win
http://media.drive.com.au/cars/car-news/motorbike-that-runs-on-air-2797531.html?&exc_from=strap
bikerburnout
Two dogs
I don't expect it to but an interesting design concept non the less.
muskrat
cool idea but my farts are louder than that.  I'm not a fan of battery anything so I give this a  [thumbsup]
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
you can carry a hand airpump with you in case you overestimated your range  [cheeky]
I bet it's pretty damn light, if nothing else it would be a fun toy  [thumbsup]
I could definitely see using one as a commuter. [Dolph]
Hell, keep a bike pump on it and you've got unlimited range!   [laugh] [laugh]
Quote from: Buckethead on November 30, 2011, 03:17:16 PM
hell, eat Mexican everyday and connect a tube to your ass
perpetual motion machine
justinrhenry
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
zooom
don't laugh, I bet they are already trying to configure that!....
2010 KTM 990 SM-T
I only laugh because I can picture myself leaving the tank open when I get to school/work and spending 20 minutes recharging so I can go home.
You only make that mistake once.
Or seriously, no more than 5 or 6 times.
I wonder what would happen if you ran it on a treadmill.
NO BP! BAD BP!
Folks have been working on air powered cars - specifically for taxi applications for a bit. Not sure where it's going as i haven't been tracking it, but in certain places it makes a lot of sense.
The one catch, right now, is infrastructure. Getting that tank filled will require you to go to a scuba or paintball shop. You need to have a air compressor that can do at least 3k psi (rating on a SCUBA) tank with a good desiccator set up. So that sort of gear isn't all that common.
But if you've got a couple tanks you can keep a reserve. And if this goes some place they might make higher pressure capacity HPA tanks in those large volumes. It's common for paintball air tanks to have a 4500psi capacity and some 5k.
The end of life, or lack of, issues are a big pro for this idea. The batteries are hugely intensive to build and only last so long. Then you've got a big hunk of narsty metals to handle
Triple J
Interesting idea.
What happens in a crash if the tank is ruptured? 3,000 psi (or a lot more) is a lot of energy to release suddenly.  :-\
Quote from: lethe on November 30, 2011, 03:33:36 PM
I thought the idea was to cut down on air pollution.
Quote from: Triple J on November 30, 2011, 07:26:49 PM
if the tank does rupture it can be bad news. Good thing is it'll probably won't be a catastrophic failure aka explosion. That doesn't happen much, save for gross over pressure or a tank that's weakened from corrosion and hasn't been properly tested.
Not sure about SCUBA tanks, but the tanks for PB (at least the 4500psi fiber wrapped aluminum) need to be periodically tested and re-certified. Fail the test and the test firm drills a big hole in it. Shops check the tanks at fill time to ensure they have a valid cert. Lower pressure tanks, and ones with different case material probably have different re-cert criteria... just don't know.
Back to getting a hole in the tank... All the pressure remaining will vent *aggressively*. The Mytbusters tested this out a bit - busting the valve off a tank for welding. Breaking off the valve at full pressure vented enough energy to put the tank through a cinderblock target. So a lot of force is captured in the tank. But if you managed to puncture the tank, it *might* toss you and the bike over backwards or similar - but if you've crashed hard enough to hole a tank like that, you've probably not on the bike anymore. I wouldn't expect something crazy like the bike shooting 20ft in the air
