January 09, 2025, 02:40:22 PM
Monobloc vs. 2 piece calipers? I need info
Topic: Monobloc vs. 2 piece calipers? I need info (Read 10849 times)
metroplex
December 01, 2011, 06:20:09 AM »
I was reading this month's Sport Rider and they talked about the 2012 Streetfighter 848's non-monobloc Brembo caliper. It looks similar in design to the calipers on my 696, which looked to me like they were cast? and 1 piece. But then I tried to find a comparison but only found photographs that showed various caliper designs that looked the same to me except for some monoblocs being machined vs. cast.
What's the specific difference in design and manufacture? I think the Brembos on my Cobalt SS Turbo are monobloc because they look machined. The Brembos on my 696 look/feel cast but I can't see how they bolt together.
These aren't the droids you're looking for
Re: Monobloc vs. 2 piece calipers? I need info
December 01, 2011, 06:31:56 AM »
Monoblock are machined from one piece of metal.
Most are billet.
2 piece are exactly that: two halves bolted together. No matter how tightly you bolt them, they can shift some under high stress and heat.
Monobloc:
no seam. No bolts holding the halves together:
P30/34: Old style 2 pad 4 piston: 2 bolted halves, Bolt heads on the OUTSIDE
P4/34: later style 4 pad 4 piston, 2 bolted halves, bolt heads on the INSIDE
metroplex
December 01, 2011, 06:35:14 AM »
Ah, that makes a lot more sense. So if it is cast, there's a better than good chance it is 2-piece and if it is machined, it is most likely monobloc?
I don't recall the seam on my 696 calipers, but I can check later in the day.
December 01, 2011, 06:42:31 AM »
Quote from: metroplex on December 01, 2011, 06:35:14 AM
i don't think the cast vs machined is the issue. a cast item can be machined in finish, this is standard for things that are investment cast.
the monobloc i posted is machined from a billet of aluminum.
the issue is solely whether you have a seam and bolts holding the halves together.
most of the radial mounts are monobloc, almost all of the axial mounts are 2 halves.
metroplex
December 01, 2011, 07:01:53 AM »
How do I tell if it is radial or axial mount?
Omnipotent Potentate
Personal Pretext
December 01, 2011, 07:26:50 AM »
Radial - the bolts holding the caliper to the fork will be parallel to the rotors face. Axial they are perpendicular.
1st photo is a radial caliper. 2nd and 3rd are axial mounts
metroplex
December 01, 2011, 07:38:22 AM »
Everything is clear now, thanks
December 01, 2011, 07:50:27 AM »
Quote from: metroplex on December 01, 2011, 07:38:22 AM
The new Dalai Lama?
booger
December 01, 2011, 09:35:15 AM »
Easiest way to differentiate -
cost
. Monoblocs are ridiculous. Overkill in every way, but beautifully crafted items indeed.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
December 01, 2011, 09:57:57 AM »
Quote from: bergdoerfer on December 01, 2011, 09:35:15 AM
cost
It's true. For racing, I would say they are necessary as they really do provide a benefit, but for street they are just bling
metroplex
December 01, 2011, 10:17:28 AM »
I recall and just checked that my stock Brembo calipers on the 09 696 are radial mount, but they look cast.
My stock Brembo 4-piston calipers on the Cobalt look machined, but checking online, it is axial mount. I don't see any type of seam on those calipers though, and I don't recall any seams on my 696 4-piston calipers - but magazines/articles stated that the Cobalt received monobloc Brembo calipers.
Personal Pretext
December 01, 2011, 10:22:03 AM »
Real monoblock calipers are VERY expensive - a base model like the 696 isn't going to have them. Two piece calipers are a lot easier to make, hence the lower cost.
The Cobalt? Like Chevy?
metroplex
December 01, 2011, 10:25:30 AM »
So what does the 696 have? Radial mount 2-piece Brembo calipers? I guess I'll have to look more closely for the seam.
Yes, the 08-10 Cobalt SS Turbocharged, with factory 4-piston Brembo front brakes (Ferodo pad compound). They look machined, with black anodizing, and they are axial mounted from the looks of it. I cannot find any seams though, but it isn't as exposed as a motorcycle. The magazines/articles said those are monoblock calipers.
Last Edit: December 01, 2011, 10:27:41 AM by metroplex
booger
December 01, 2011, 10:40:55 AM »
It's true! Monoblocs on a Cobalt. The wonders never cease.
Isn't a Cobalt an updated Cavalier or something?
That SS Turbo is actually a pretty hot little car. Hot as in rodded, not neccessarily hot as in
hot
It's a bit of a stretch to realize GM would put Brembo Monoblocs on a Cobalt, but that's what appears to have happened in the case of the SS Turbo. Maybe all SS Cobalts. Those are $23,000 cars.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2008 BMW R1200 GSA
Personal Pretext
Reply #14 on:
December 01, 2011, 10:44:36 AM »
From the photos I looked up - they are cast and anodized or painted on the chevy. They appear to have external hoses linking the two halves, so they could well be a single casting, that's externally plumbed. Those external hoses would do a lot to keep the costs down. There may be some machine work done - but they won't be billet.
So it seems the Cobalt has monoblock calipers, but they are cast and externally plumbed
Any billet parts start of as a solid block of metal and an subtraction is done via CNC or other machine process. Cast parts are, well, cast into the rough shape and minimal machine work is done to ensure proper sizes, threadings etc.
Billet Moto-mono blocks (like the first photo) have all the passages inside, which takes a lot of fiddly, time consuming machine work. Time = money.
The 696 has Radial 2-piece calipers
