Pod Filters
Started by memetic, December 15, 2011, 03:20:04 PM
memetic
Does it really make that much of a difference? I can read about it, but can you actually feel the difference in performance -- not just the sound? Thanks.
2002 Monster 900
scduc
Some of the experts will say that pods actually hinder performance. I'm not a racer,  if I were, I'd be riding an R1. With the proper tuning, my bike runs great. The vaccum noise doesn't kick in until throttle is wide open and rpms hit 5k. Then its awesome. now my hearing is somewhat impaired so there may actually be some noticeable difference, but with my helmet on I can't really tell. And just doing the pods is not recommended unless ECU and exhaust are upgraded.
xcaptainxbloodx
large amounts of quiet air make for better runnabiliy and higher HP. pods look and sound cool but the real benefit to them is to open up space for things like larger tank capacity or to hide things.
I would guess pods cost ~3-5hp, nothing major. If you're running carbs they will be a pregnant dog to dial in and will operate in a narrower margin (in terms of temp/humidty/altitude). Not enough to keep you stranded unless you go through some major changes but enough to make the bike irritable for sure.
Bill in OKC
My bike runs better with DP ecu, Arrows and pods than it did stock.  It might have more power with the airbox but I'm just glad it doesn't randomly cough and die anymore.
Mine probably lost power but if so only a little. I like the look and sound and the other thing it lost was a precious pound or two.  [thumbsup]
Ive dyno tested both on my 95' 900 Monster.
I settled on an open airbox with some mods to the velocity stacks.
On the dyno, without the bike hurtling through the atmosphere, I found only 1_2 hp/lbs difference. Some say that in the real world, with on road conditions, the difference is much greater. This required some more tuning to get the best out of each set up.
The pods had different flow characteristics to the open airbox with K&N filter at various throttle openings.
One thing I hold a strong position about is that  appropriate velocity stacks will be important whether you use pods or an air box. That and careful tuning.
Look up pods vs airbox and long vs short v stack threads. If you need some base settings I'd be happy to help.
Cheers.
brad black
are you comparing a std airbox lid to pods or an opened airbox (cut up lid)?  pods will definitely make more power than a std airbox lid.  possibly a little less than an opened airbox.
but, the quote below is behind many pod mods, so if it's part of a goal you take your choice and stick with it.
Quote from: lethe on December 16, 2011, 12:50:07 AM
personally i think pods inside a large airbox may work better, but no one has yet built a box around them afaik.  i did it for a hotted up 888.  overall it made good power, but i didn't have a std airbox baseline for it.
Brad The Bike Boy
http://www.bikeboy.org
I dynoed open air box and pods. I also compared different length velocity stacks within the open airbox. The pods were K&N 1750s. The K&N filter in the open airbox was the DU 0900 commonly used.
Personally, and I hope to one day prove this.
a large airbox with forward facing intakes and a large K&N filter or filters with enough surface area to at least double stock airfilter.
then variable length intake trumpets that are short during low RPMS and long at high RPMS, using either a small motor/rheostat hooked into the rpm circuit
or trumpets that vary in length depending on throttle input using a cable from the throttle bodies.
dropstharockalot
My intake note is different now... more of a low, steady moan than with the cut-up airbox and K&N filter I had before my pods.  When I was running the cut airbox and K&N, my intake sound was more of a pulse... kinda a "pom-pom-pom-pom" vs. my current "uurrrrrrrrrrrrttttttt."  I prefer what I'm hearing now.
BTW, those are scientific terms.  You can find them on page 37 of the 1996 M900 shop service manual.
My un-scientific seat-of-the-pants dyno tells me that the bike is spooling up and getting into the revs quicker, but it's also blowning past the meat of the torque range quicker.  I do believe that the statements about overall HP loss as shown on the dyno are accurate, as I can't scare the crap out of myself at 120mph anymore... I have to settle for pooping my pants at a mere 112 or 113.  The trade-off is getting there quicker and getting to flog my shifter a bit more... I'm good with that.
Plus it just looks badass...
'96 M900
Quote from: brad black on December 16, 2011, 03:03:31 AM
Brad, have you documented this on any of "your" bikes over the years?
True before/after from open lid to pod mod?
DoWorkSon
My bike dynoed 7hp over stock with pod filters/exhuast/tune.... I noticed much higher top end power but a decline or flat spot at mid range..
I liked them and thought they looked great... If I could do it over again I would try an airbox/pod filter combo setup
2009 M696--SOLD
memetic
I have sil-moto exhaust and aftermarket ECU already. I want to do something with the intake (even if it is only for cool sound), but NOT for a loss of power. I want to get a program that allows me to change the settings of my ECU also.
2002 Monster 900
I once had a 900 Monster back in '96 that made 74hp stock and 77 with slip ons, open airbox, K&N filter and dynojet kit. The open airbox let the bike hold onto it's top end power better, but the increase in midrange power and torque was substantial.
brad black
Quote from: stopintime on December 16, 2011, 10:23:51 AM
i've never fitted pods to anything i've owned.  the original airbox is just far too convenient
Brad The Bike Boy
