Exhaust; one warm, one cold?
Started by mysticbluex3, December 16, 2011, 09:57:23 AM
mysticbluex3
So I noticed that when I'm warming my bike up in the AM, the exhaust coming out from one side is warm and the other side is cold?  Why is that?  Its a 09 M696.
I have that and I blame it on global warming.
I've heard it's normal, but I can't say I understand why.
My guess is it has to do with exhaust flow being uneven between the two pipes.
If it happened on a bike with two individual pipes and cans, it would need work...
[popcorn]
Skyshadow
Your mufflers are cold? like after the X pipe?
- Homemade Exhaust
- K&N filter
- Tail chop w/ integrated tail light
- Sliders
Quote from: cupcake on February 19, 2012, 04:53:56 PM
My rear brake is just for looks.
battlecry
It is the Coriolis force.  If you take your Monster to Oz or Argentina, the hot and cold mufflers will reverse.
alibaba
2009 M696  -  exactly the same issue.  I would like to hear a definitive answer.
I wonder if I turned the bike 180 degrees if the issue would change sides?  ;-)
Two dogs
Did you check if a kitten had crawled into one.
Dellikose
Quote from: Two dogs on December 17, 2011, 04:35:52 AM
Hahaha... "I have fur coming out of one of my pipes ???"
1999 Ducati M900
actually not a joke. i've heard of things crawling in the pipes. check for flow
as far as cold hot. if you look at the flow of the exhaust you'll see one flows more smoothly, less turns for the exhaust to snake.
Quote from: battlecry on December 16, 2011, 05:27:27 PM
[laugh] [beer]
ManaloEA
Quote from: Raux on December 19, 2011, 11:52:57 AM
Wouldn't that cause different backpressure? And therefore different performance between cylinders?
2011 M696
After the crossover. should be no issue
