February 22, 2025, 03:13:37 AM *
Author Topic: Duc.EE for the Monster 1100 EVO  (Read 2328 times)
coffeegrinds
« on: December 23, 2011, 08:07:47 PM »
Just installed a Duc.EE by Vizitech for the 1100 EVO.
If you get a fender eliminator for the 1100 EVO, the underside of your tail will have a weird box sticking down about an inch or so.  The box is necessary because the servo actuator (or valve actuator or whatever mechanics call it) takes up so much space in the tail.  It may not be that big a deal, but if you want your tail section more streamlined, you can install the Duc.EE in place of the servo actuator.  It'll get rid of the clutter and excess weight of the actuator.  From what I've been told, the servo actuator is pretty useless, but I'm no expert on that.  I guess you could just remove the actuator without replacing it with the Duc.EE, but you'll get an check engine light or error code on your tach.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #1 on: December 24, 2011, 02:45:00 AM »
Yup,  Duc.ee is a nice little solution to eliminating the exhaust servo motor's bulk whilst keeping the ECU happy waytogo
« Reply #2 on: December 24, 2011, 02:51:14 AM »
The Duc.EE is also sold as a Motocreations part. I think the two companies worked together to develop it, but noticed Vizitech removes the Motocreations logo from the product on their website.
cyberswine
I Just Washed and Waxed my
2011 796 ABS
« Reply #3 on: December 24, 2011, 10:37:13 PM »
I read on another site that if the cable is disconnected (with the motor connected to the wiring harness) the valve defaults to open and there will be no EXV error reporting.  Mine's laid up now so I can't check that, can anyone confirm the info?
"Life ain't no box of chocklits when you is born a idiot"
Forrest Gump
« Reply #4 on: December 24, 2011, 11:00:39 PM »
true but now you have a three lb dead weight
DucNaked
« Reply #5 on: December 26, 2011, 10:19:28 AM »
And a check engine light.
