Noise levels for exhaust noise ,NSW
Started by FIFO, December 28, 2011, 04:38:22 PM
FIFO
This is a good read ,Teff
And will probably not apply to most of us here  :-X
http://www.environment.nsw.gov.au/noise/vehiclenoise.htm
And clause 19 appears removeable baffles arn't legal either
Modifying or repairing a vehicle so that its noise control equipment is made defective, is not securely in place is missing ,
or has temporary noise reduction devices or packing fitted (clause 19)
The Regulation also makes it an offence to use temporary noise reduction devices or packing in vehicle exhausts. This includes items such as baffles in the exhaust system that have not been
welded/riveted in place, or items that are adjustable such as valves, or materials introduced into the exhaust system, such as steel wool. These items must not be used to defeat a noise test.
However a defence is provided for any:
• vehicle that, at the time of manufacture, had items such as baffles that were not welded or riveted in place or an adjustable device in the exhaust system, or a replacement that is equivalent to that fitted by the manufacturer
• motorcycle that has items such as baffles that are bolted or otherwise securely fastened in place.
Avoid fitting your vehicle with a pod-type air filter. This filter increases engine induction noise and may also increase exhaust gas pollution.
Road Rule 291 - requires that a person must not start a vehicle, or drive a vehicle, in a way that makes unnecessary noise or smoke, e.g. unnecessarily revving a vehicle when it is stationary or repeatedly opening and closing the throttle when the vehicle is in motion.
Police officers can also issue three demerit points for this offence.
Office of Environment and Heritage (OEH)
Environment Line: 131 555 (local call cost - NSW only) or (02) 9995 5000
Two dogs
Anyone got a DB meter ?
Think I may have some issues , great another fine is all I need  [bang] NOT !
Think Brian got off easy didn't get booked for no rego sticker and didn't get an automatic ticket for
noise pollution , just a big fat inconvenience .......bastard's.
mattyvas
So is there a wash up from the incident on the old road last week?
Is that what you are referring too TD?
The other info would put a huge industry out of business.
How many of us and other bike riders for that matter have a standard exhaust.
Betty
'They' brought in a law a few years back that all aftermarket pipes (bikes only, not cars) had to be stamped with the dB reading measured under controlled conditions ... but that was quickly repealed - as bikes beyond a certain age [read: those that were really loud stock] would all have to be individually tested and stamped ... and very few of them would have been deemed 'acceptable'.
There was still a dB reading that you were meant to be under (certain revs measured a certain distance from the bike) but the average LEO possessed neither the equipment nor the expertise to be able to make an accurate reading. Perhaps this is the reason for sending a certain someone's bike 'over the pits' ... but obviously this serves very little purpose.
I am pretty sure when the Boss got a blue slip for the Lammie there was no noise test done ... and she is quite loud (yes, yes ... the scooter too).
Betty
Quote from: mattyvas on December 28, 2011, 11:02:57 PM
Unrelated ... but it was a fear I had at the time (as well as things like tail chops, lack of chicken strips, etc)
This is part of what killed the temporary law that was shot down a few years ago (also that it was completely impractical). Staintune were jumping through hoops and offering a 'tagging' service. It doesn't work on the large scale that you are talking about.
Regardless, it all seems quite discretionary.
What happened to those 'noise cameras' that were being trialled down south? Did any of that work? Still in operation?
reebok
In Vic, a 'concerned citizen'  can report your vehicle to the EPA, you get a notice in the mail to report to a testing station within a time period.
You get fined and the process starts again if you dont attend.
If you attend and dont meet the rules, you get fined and defected.
And the 'concerned citizen' doesnt need to record their name or contact details, even if they are categorised as a 'vexatious litigant' by the courts.
So, you get dobbed in, you have to pay for the testing, and more if you dont.  The dobber doesnt even have to be named.  If your neighbour hates you, or your girlfriends mum doesnt want you around, here is their chance.
My sister used to work for the EPA, and some of the more 'committed' employees (activists) would take home a pad of complaint forms for weekend 'spotting' use.
same applies for exhaust smoke .
braando
Thought i would go for a peaceful, sedate ride out to the Nthn Beaches, 5k's under the limit all the way.....spotted the booze patrol lined up on Mona Vale Rd just before St Ives.....they saw the bike coming and made a beeline over to flag me down.. Three of them came over but didn't quite know what to make of the bike, being an MV.  One prick started at me for not displaying a rego label which is understandable i guess, while the other piped up saying that the exhaust is for race use only.....I don't think that the silly shits quite knew what to make of it. The four organ pipes at the rear aren't all that common.......Then he asks me to start it up, then rev it..... i'm handed a form saying that the dept of environment and climate change will contact me to arrange for it to be tested, failure to do so will equate to a $2,500 fine..........
NOTE..........they still haven't breath tested me.......
KU HWY Patrol..........Gordon....SC Boyd.......  do i sense a familiarity here   ?
I was pleasant, no smart ars remarks.......but their arrogance and comments were pretty lame. If i'd let loose they would have done me for the rego label plus anything else that took their fancy.......Arsholes to put it mildly.....
It puts a sour taste in your mouth, to the extent that i'm close to flogging both bikes off....but then i think, thats probably their objective.......
This was supposed to be a random breath test unit, .and they wonder why most motorcycle riders loathe them........enough said......preparing tonights dinner, menu below........... [evil]
techno
Thank God they don't bother with the noise testing crap in Tassie. It would probably put half the bikes off the road. They have enough problems with young kids ripping around the streets on unregistered chinese dirt bikes to keep them busy.
Don't let em get you down Teff.  [thumbsup]
Quote from: ducmeister on May 24, 2012, 01:45:16 AM
Hey Techno you are a smart man.  [thumbsup]
Had an accident in Tasmania? - www.tas-compo-law.com.au
monstermick58
Geeze Bwian,
      Is that just your Northern Beaches arrogant Copper?
Or does this happen to you anywhere you go?
                                  Mmick
Two dogs
The four musketeer's have all (one may be missing due to Aust Post or other suspect activeties  [laugh] ) received love letters from the Gordon  [bacon] [leo]  [bacon] bacon farm
looks like a video night at the station to decide next course of action  [popcorn] anyone .
What is it with this particular precinct , did some Gixer boy racer run over the stations kitten.
braando
#10
Just Xmas time i'd say mmick........all leave cancelled for  our fearless blue caps........plus they can't claim stress leave when they so much as fart anymore, so they are not happy campers....It is mainly around the Nthn Beaches & Pacific Hwy thats being targeted from my experiences that is..........look, there are always two sides to this argument......I have been riding the old rd around the speed limit, then overtaken by some idiots double my speed who deserve to be done......just ask Suzy, she has encountered a few on her push bike.....though that would be the last place that you'd catch me on one, pushbike that is......
The visit to the DECC to be tested should be interesting (Dept of Environment & Climate Change), stock exhaust, cat fitted, standard ECU, I just wonder though, as I arrive.  Do I park my bike around their Prius's, or amongst all the pushbikes....?    [roll]  [roll]
suzyj
Quote from: Brian W on December 29, 2011, 05:20:52 AMI have been riding the old rd around the speed limit, then overtaken by some idiots double my speed who deserve to be done......just ask Suzy, she has encountered a few on her push bike.....though that would be the last place that you'd catch me on one, pushbike that is......
Not so much done as just laughed at by their mates.  I have no issues with riding quickly (I do so myself) - it's treating other people on the road badly that makes me want to spank people.
As for loud pipes, I  would understand if the coppers were waiting outside the house for you to start it and rev it like a twit at 7am, but out on Mona Vale Road?  Please!
Yellow Meanie
Quote from: techno on December 29, 2011, 02:42:44 AM
Thank God they don't bother with the noise testing crap in Tassie. It would most likely put Mr. Meanie's bike off the road.
Even the motorcycle copper, who let me off with a warning for 12km/h over, didn't say anything about the noise  [laugh]
techno
Quote from: Yellow Meanie on December 29, 2011, 01:37:13 PM
Same here Dave. They didn't even bother to look at my CF Arrows stamped with "not for road use". They did write me a ticket for my speed though. I have challenged it but not received the summons yet. I will see how far I can get with it.
Two dogs
Quote from: techno on December 29, 2011, 02:13:04 PM
Techno what were the circumstances that lead to your challenge  ?
[popcorn] I have a vested interest in this activity and its outcome ;D
