February 22, 2025, 03:37:20 AM *
Author Topic: Oil Line Re-locate/Replace?  (Read 1478 times)
DTR
« on: December 31, 2011, 04:55:45 PM »
I'd like to clean up the appearance of the right side of the engine. I will lengthen and re-route the electrical, but the oil cooler line is an eye-sore:
 I looked at My Multistrada to see if those lines would work ,but they look too long. Has anyone re-routed or replaced this oil line to have a cleaner visual appearance? If so, what Ducati did the longer oil line come off? Thanks, in advance
Nomad
« Reply #1 on: December 31, 2011, 05:01:45 PM »
I'm not 100% sure, but I think there is a Motard kit that is a direct swap, more or less...
DucHead
No garage queens
« Reply #2 on: December 31, 2011, 05:17:18 PM »
Or you can make your own.  A search will find both.
« Reply #3 on: December 31, 2011, 05:22:57 PM »
Oil lines for the HyperMotard will re-route it to the left side of the engine.
I got mine from PJ's parts and they bolted right up.
Be careful when you're switching lines, tho. The cooler is not very strong at all, so use the cast-in backing nuts when loosening the lines.
I'd also recommend liberal dosing of penetrating oil when wrenching the lines off the engine. The casting in that area is not very strong and has been known to break off a piece when the fittings finally come off. Happened to me and at least one other that I know of (Triple J). JB welded back in place, but I'd rather have not had to.
scduc
« Reply #4 on: December 31, 2011, 07:17:01 PM »
I bought mine relocator lines from PJ's parts as well, I also painted the radiator while I had it off. Definately cleans up the right side. Now I just want to re-route the temp lines and the starter cable.
DTR
« Reply #5 on: December 31, 2011, 08:27:21 PM »
The ones from PJs.....are those the Fren TUrbo for Motard? ~$123.00?
« Reply #6 on: December 31, 2011, 08:38:57 PM »
Yup. Them's the ones.
DTR
« Reply #7 on: December 31, 2011, 08:55:07 PM »
Great, thanks. I searched for a DIY mod, but no luck. Different search terms?
xcaptainxbloodx
« Reply #8 on: December 31, 2011, 09:40:14 PM »
just pick up some used hyper lines on ebay. direct swap for what you want.
madalf71
relaxing at home
« Reply #9 on: January 02, 2012, 05:18:21 AM »
Save you some searching
http://ducatimonsterforum.org/index.php?topic=15261.0
And yes, use two spanners on the oil cooler.
erichan8757
« Reply #10 on: January 03, 2012, 10:27:04 PM »
Motard is direct swap
or you can do something like the This sportclassic guy did
E
07 GT1000
06 M620, [SOLD]
Modifications are never too many.
