February 06, 2025, 08:14:43 AM *
Author Topic: fitting new exhaust on M796  (Read 971 times)
digital
« on: January 02, 2012, 12:01:09 PM »
Like the look of new M1100 evo exhaust (with termi) a lot.
Can one fit the 1100 evo exhaust on M796? Would ducati bring out an M796 evo soon?
wannabfast
« Reply #1 on: January 03, 2012, 09:55:59 AM »
i doubt the 796 will get an evo designation, as far as fitting an 1100evo exhaust on a 796, it may or may not work, i would lean towards not really because of the height of the cylinders are taller i think, the heads are identical sans cam sensor
« Reply #2 on: January 03, 2012, 12:05:20 PM »
the evo exhaust wont work on the 796 without custom work
digital
« Reply #3 on: January 03, 2012, 04:24:47 PM »
thinking of it, makes sense as the 1100 cylinders are taller, it is likely not to fit without custom work.
would fitting 1100 evo pillion pegs have the same issue or can be fit on 796?
Curmudgeon
« Reply #4 on: January 03, 2012, 06:26:37 PM »
It's only money.  Wink Next time you visit your dealer, have a look at the way they are mounted. You might need the whole rear subframe..., or not. The main frame is the same I believe. You might want to check the parts numbers.
