February 06, 2025, 07:54:12 AM *
Author Topic: MotoGP engines - Design & Road-going Counterparts  (Read 1440 times)
loves ze desmodromics.
« on: January 03, 2012, 07:27:40 AM »
Its cold here, especially today, and I was taking a work break to think about motorcycles - warm thoughts that pass the winter doldrums more pleasantly.
So today I was thinking about MotoGP engines, and unfortunately I don't have a whole lot of information on what each manufacturer is or has been using recently, but with the addition of CRT and the Aprilia GP 'superbike', I thought I'd see if anyone else has any good technical information.
Ducati uses the desmosedici engine: V4, displacement formerly limited to 990cc and 800cc depending on rules. Well V4 motors make it into production, if not only on the Desmosedici, also on the Honda VFR, Aprilia RSV4, and forthcoming Motus (iirc).
Honda has used a V-5 in the 211 - but I've read its a V4 in later years.   I'm unaware of any showroom floor model ever equipped with a V-5.
Yamaha seems to use a more conventional I4 setup.  Not unlike their production machines, I suppose.
Here's just one of many links I perused: http://www.maclean-nj.com/2002motogpengines.htm
off to the coffee pot now, your turn.   coffee
« Reply #1 on: January 03, 2012, 08:33:15 AM »
I think Dorna putting the rule of 81mm pistons has really put a damper on the series and it's motors
Imagine a short stroke Superquadrata as a CRT!
« Reply #2 on: January 03, 2012, 08:43:38 AM »
This will get you up to speed on what engines have been used recently and what is in use now:
http://en.wikipedia.org/wiki/Grand_Prix_motorcycle_racing
« Reply #3 on: January 03, 2012, 09:10:24 AM »
So was thinking about the 81mm bore limit and 4cyl limit. I think this was designed to keep the twins out of the competition.
imagine a superquadrata with the same 112mm bore with a 50.75 stroke.  a 2.21 ratio a supersuperquadrata!
# cyl = bore x stroke with 81mm bore limit  vomit
2 cyl = 81mm x 97.03mm
3 cyl = 81mm x 64.68mm
4 cyl = 81mm x 48.51mm
« Last Edit: January 03, 2012, 09:13:23 AM by Raux » Logged
« Reply #4 on: January 03, 2012, 09:19:34 AM »
Seems like with a bore-maximum prescribed, its advantageous to run as many cylinders as possible (within other design constraints obviously, such as weight distribution, width, frame design elements, etc)
« Reply #5 on: January 03, 2012, 09:21:00 AM »
I had read that one - was hoping for some good layout diagrams of the various works-motors.
derby
« Reply #6 on: January 03, 2012, 10:33:40 AM »
there hasn't been a twin in the series since the 2-stroke era even with the rules allowing them (with a significant weight advantage) in the 990 4-stroke era.
-- derby
'07 Suz GSX-R750
