February 22, 2025, 08:05:16 AM *
Author Topic: help identifying rearsets  (Read 1679 times)
JoeP
« on: January 03, 2012, 11:42:37 AM »
I just got this bike a month ago and can't seem to identify the rearsets. Any ideas? Also, if you look closely at the pic, you'll see some venting hoses running down near the pipes just in front of the rear wheel. Should I reroute these? I'm worried that whatever is coming out of them might make a slippery mess for the rear wheel, and that the hoses are getting melted by the pipes. New to motorcycles, so any help is appreciated.
« Reply #1 on: January 03, 2012, 11:51:55 AM »
not sure on the rearsets... might help with some upclose photos
the tubes look like they went to the charcoal canister, maybe. it's an emissions thing that a lot of people remove.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #2 on: January 03, 2012, 12:10:19 PM »
BCM?
http://www.ducatimonsterforum.org/index.php?topic=198.msg1003566#msg1003566
Some Dude
« Reply #3 on: January 03, 2012, 12:13:41 PM »
Rosmoto.
Only pic i could find is Here
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
bacon        bacon        [
JoeP
« Reply #4 on: January 03, 2012, 12:26:47 PM »
I think that's it. Thanks!
Rosmoto.
S2R 800 '07
« Reply #5 on: January 03, 2012, 12:29:39 PM »
At least one, maybe both those hoses are gas overflow.
They are usually routed between the stock rearsets and engine block - just outside the pipes.
You can put a bolt in one of the no-longer-in-use holes on your engine block and secure the hoses to it. Leave enough slack in the hoses to allow the tank to be lifted without pinching/stretching the hoses.
« Reply #6 on: January 03, 2012, 12:42:45 PM »
ah so, the new monsters have them at the front left of the motor.
JoeP
« Reply #7 on: January 03, 2012, 01:27:44 PM »
That sounds right. I'll pull the tank up tonight and double check. Then I'll re-route them like you suggested. Thanks!
« Reply #8 on: January 03, 2012, 03:44:36 PM »
From the photo they look like the drain tubes from the carb float bowls.
S2R 800 '07
« Reply #9 on: January 03, 2012, 03:57:28 PM »
Aren't those the ones seen just under the oil sight glass?
« Reply #10 on: January 03, 2012, 07:05:37 PM »
Yes, except I think the have been mo...oh! never mind.  I just looked at the photo again.  They are still there.
JoeP
« Reply #11 on: January 03, 2012, 08:06:19 PM »
The hoses in question are indeed the gas overflow lines. I rerouted them inside the swingarm and away from the pipes where they were getting fried.
