February 22, 2025, 09:05:36 AM *
Author Topic: Rizoma Zero 11 Help  (Read 2387 times)
SkimBom
« on: January 04, 2012, 04:34:47 PM »
First off, Ive done my best searching and maybe i missed something but...
I just bought 4 Zero-11's and all the install forums ive read talk about "The Black Box" and if i dont use it, the world will explode. Well, mine didn't come with a black box. I got two resistors per, no box. I just bought them new from monsterparts. What am i missing, new zero's don't need black box or should i be looking for a black box?
 I have an 02 620 if that makes any difference.
and since you are here, how many resistors should i use?
Thanks guys bow down
S2R 800 '07
« Reply #1 on: January 04, 2012, 04:46:29 PM »
The black box was/is there to change the voltage. Maybe Rizoma finally went 12 volts.
Call Jeff - he'll know waytogo
« Reply #2 on: January 04, 2012, 05:17:32 PM »
The resistors are the black boxes.
SkimBom
« Reply #3 on: January 04, 2012, 05:19:49 PM »
Thanks
I just went to the Rizoma website and they list them as 12v now in the tech specs.
Thanks for the reply.
NateNewThread
« Reply #4 on: January 04, 2012, 07:31:57 PM »
I simply assumed "the black box" always meant the stock electrical connector that comes on the ducati, not the resistor. If you have a 696/796/1100, one resistor will be fine. this shit aint rocket science people.
S2R 800 '07
« Reply #5 on: January 04, 2012, 10:27:47 PM »
If Rizoma went 12 volts this is of historical value only, but this thread shows it all.....
http://www.ducatimonsterforum.org/index.php?topic=32690.0
« Reply #6 on: January 04, 2012, 10:28:56 PM »
THe resistors don't change the voltage, they change the ohm rating of the light.
The stock lights on the 696 are 10ohm. LEDs are less than that so you have to add more resistance.
All lights for motorcycles (with 12v systems) are 12v lights (or in the case of the convertor box for the Rizoma, 12 V compatible), otherwise.. POP!
« Last Edit: January 04, 2012, 10:34:42 PM by Raux » Logged
SkimBom
« Reply #7 on: January 05, 2012, 12:13:47 AM »
Signals installed!
no load/converter/black box (whatever you want to call it) just one resistor and NO POP. waytogo
Thanks
Bill in OKC
S4Rs
« Reply #8 on: January 05, 2012, 09:27:13 AM »
I'm glad to hear they have gotten rid of that box.  I can put Rizoma signals back on 'the list' now.
OT
Still Sweeping.....
« Reply #9 on: January 05, 2012, 10:06:21 PM »
Who'd you buy them from?
JEFF_H
« Reply #10 on: January 06, 2012, 02:01:12 PM »
There used to be two boxes, one the power and the resistor.
then the big power box was replaced by a small power box
now just the resistor.
there are instructions for installing with 0, 1 or 2 resistors...ducati's take 1 resistor (as has been said)
SkimBom
« Reply #11 on: January 07, 2012, 02:37:09 PM »
I bought them from mosterparts.com along with a bunch of other stuff. I had no problems at all and will buy from them again.
S2R 800 '07
« Reply #12 on: January 07, 2012, 02:48:24 PM »
I'm not sure I'd trust them - you never now where they are lurking - maybe closer than you think  Grin
corey
'06 Tang/Black S2R800
« Reply #13 on: January 09, 2012, 10:35:39 AM »
lolz.
