anyone tried these or similiar adjustable footrests
Started by 118811, January 10, 2012, 02:31:02 PM
They work as advertised - clever design if you ask me.
Only reported 'problem' is that they move your feet out a little, but I guess that's subjective.
They are great.  The look isn't as compatible as I'd like (S2R) but they work as advertised.
118811
Thanks guys for your educated opinions!!
yeah...I thought they might be kind of fun to try.....
I am 6' and I am about to install rear 30mm rear risers (hoop) and thought might give these a try as well
u guys see any conflict issues doing both?
Quote from: 118811 on January 10, 2012, 02:51:50 PM
I don't see a conflict, but a 30 mm hoop raise will change your bike some.
No FHE with it, but maybe you should adjust a little first and see how high you are comfortable with?
BTW - where did you get your hoop risers?
118811
Stopintime,
I got the spacers from a member here on the board.  I placed an ad in parts wanted...even had another member offer his extra set.
Regarding the 30mm rear situation...I do plan to raise my forks back up in the triples if need be...I have about 8mm there.
It really seems to be a touchy subject with a lot of riders (love it or hate it) situation!?
Since they are a simple bolt on, if I don't like them...their out.
Thanks again for your interest and opinion.
Aloha
118811
Gonna get a pair...
They come with either 24 or 30 mm offset options
Which one should I go with?
Quote from: 118811 on January 11, 2012, 10:51:50 AM
Gonna get a pair...
how long are your legs?
Most of these are sold as separate pieces - you can buy both arms now or another one later.
Both will feel very different.
118811
Quote from: ducatiz on January 11, 2012, 10:57:13 AM
I am 6'
with 33' inseam
also, wondering now will I be able to retain stock shifter & brake
Always had wondered about the reverse shifter as well....thoughts?
BTW  there are some differences between Monster models regarding fit. Back when the original German manufacturer was the only source for them AND screwed up their model/part # charts, people kept getting the wrong brackets and had to grind them down to fit. The SSR brackets CAN NOT fit all the models they list, so be prepared.
You'll be able to keep your stock foot controls, but it could be a good idea to check how you need to adjust them and see if that's possible. I'm not sure you can adjust down 30 mm, as an example. If you can't, and still like these, there are aftermarket gear shift rods. Not sure about aftermarket brake pedals...
118811
Quote from: stopintime on January 11, 2012, 02:09:55 PM
Thanks, StopInTime
Yeah, I am prepared to do some fine tuning on the peg fit...I have a grinder!!
Think I will try the shorter version first and go from there.
Ak1nza
Quote from: 118811 on January 11, 2012, 02:32:59 PM
Thanks, StopInTime
Let us know how it goes.  I'm 6'1 w/ a 32" inseam and this could be something I'd do as well!  My knees are just slightly high on the tank w/ the stock pegs and I want to move my feet back just a tad to counter that and this might just work!
2006 S2R800 Dark - SOLD
2007 S4RS
118811
 [Dolph]
Quote from: Ak1nza on January 14, 2012, 06:22:51 AM
Exactly, I have a used seat coming too....which I plan shave the back , (just before the cowl)
Flat so I have more leg room
I think by raising the rear, new footrests moved back along with the new seat
I might be a little more spread out on the bike
Best thing about doing these mods ...fairly cheap, & they're all reversible
I ll let u now how they turn out
imaspecialparts
Also to note, the footpegs of this type must space out the feet more over stock position for the hinge - so this makes the bike slightly wider.  For many, this is not a problem - but Monsters have wide "American Cowboy" seating and feat position to begin with!
For raising the forks in the triples and adjusting the hoop height, I suggest you take measurements and do math to find your motorcycles angle, rake, trail, and wheel base!  When you adjust the angles of the suspension linkage, you may also need to adjust the settings of your shock to compensate.
IMA Special Parts - North America
Volpiano, TO, Italy - Nashville, TN, USA
IMA Special Parts designs, tests, and manufactures billet 7075 ERGAL adjustable-offset and conventional triple clamps, adjustable clipons, riser clipons, bar risers, fork damper clamps, and accessories for Ducati Motorcycles and most modern superbike
