Metal Tank for an S2R
Started by TitanMonsterS4R, January 20, 2012, 07:13:13 AM
TitanMonsterS4R
UPDATE
Spoke with the folks at Tanks by Tigman.  We're moving forward on a steel tank  (easier to paint and half as expensive as an alum. one).  It might be a bit heavier than stock but I can deal with that.  I owe him photos from a couple of angles of the tank.  Top, back, bottom sides, area where the fuel pump goes and gas cap area.  Someone wouldn't have those handy would they??
TitanMonsterS4R
Quote from: Raux on January 24, 2012, 12:58:12 PM
What are the exchange rates like for the Beaters?
http://www.moto-works.jp/beater/index.html#d9
About $2200.00 USD.  Assuming that this doesn't include shipping, so add another $300.00 to that or so...
Quote from: MadDuc 20/20 on January 24, 2012, 09:11:49 AM
UPDATE
Just get one of these and bolt it on should work fine
from another site
Well, that is something good that we do not let anybody wait for more than 1 month. We can produce approximately 10 alloy tanks in a month. Steel tanks (any number required per month). For ducati alloy tanks, we might take some time for the first tank to make mounting jigs and other fixtures, templates etc. Once the first tank is ready, we can do around 7-8 ducati tanks per month.
Steel tanks are no problem for us but they'll be heavy. Alloy tanks go well with these bikes.
Unfortunately, i am not a fabricator myself but i get everything done by professionals and duly check them on mounting jigs to make sure it fits perfect and for any leaks.
We just need a frame to check the fitting but we will probably not need it as the jigs we make are made according to the tank design. We make over 70 different style of tanks with the jigs we have for them and every tank fits perfect on customer's motorcycles. So, this is not a big problem.
The biggest problem currently is to get a sample tank
__________________
Vintage and Classic Automobile parts.
Thanks and Regards
Rohan Nino Puri (Director)
Vintage Auto World
Website:
http://vintageautoworld.trustpass.alibaba.com
Picture gallery:
https://www.flickr.com/photos/vintage...ld/collections
Quote from: Raux on January 24, 2012, 01:19:20 PM
__________________
Thanks and Regards
Vintage Auto World
That is the guy I was talking to and I have a tank to send him.  I am just working out the shipping.
TitanMonsterS4R
Quote from: ducatiz on January 24, 2012, 01:38:49 PM
Pming you....
jgrm1
Make sure it isn't swollen.  I'd hate to see a metal tank with the wrong dimensions (ha ha).
-Jeff
BMW:  2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati:  2008 S2R1000, 1998 900 Supersport Final Edition
Norton:  1974 Commando 850
Triumph:  2016 Thruxton R, 1971 T120R
Quote from: jgrm1 on January 25, 2012, 06:35:36 AM
-Jeff
lol thanks
Uncle Mofo
I have a S4RS tank available
                                   2007 red S4Rs
kittay
I was curious about the fuel pump variation between the monster 620 and the s2r. I realize the size/ placement varies because of the different composite of the tank. But what I am wondering is if the fuel pump's output is different? Is there a different flow rate/psi between the two?
TitanMonsterS4R
#72
Quote from: kittay on January 25, 2012, 11:07:46 AM
Answer kinda addressed by Duck-Stew's earlier comments:
early finished with a steel tank swap onto a 2007 S2R1000 right now.
Besides ALL of Speeddog's comments (which are right), here's my additionals:
Fuel pressure between steel and plastic tank bikes is common @ 45psi. So, you'll need to plumb in a pressure regulator from a steel tank bike to make the system hold pressure.
Steel tanks from 2000/01 M900's are NOT compatible. Do not buy unless you want to do major fab work under the tank (although they hold a bit more fuel...).  Only get 2002-early 2005 tanks. (2005 was a split production year for tanks with early being steel & late being plastic).
You'll also need the tank hinge bracket & hardware.
On this swap (also a formerly dented tank), I had the tank hinge area welded or brazed up before doing the internal coating so as to avoid future issues later.
Also, old internal fuel lines get weak and brittle.  Buy NEW submersible fuel lines to go in the tank as replacement is a PITA later.
Look for my latest custom to debut later this month or February...
Someone with a metal tank send me pictures of the hinge mount (seat removed, tank down, tank up, rear, side)?
thanks
Quote from: ducatiz on January 25, 2012, 01:13:17 PM
thanks
Would photos of an old carbie tank work?  I think it is the same hinge.
