Metal Tank for an S2R
Started by TitanMonsterS4R, January 20, 2012, 07:13:13 AM
Quote from: howie on January 25, 2012, 01:26:24 PM
Would photos of an old carbie tank work?  I think it is the same hinge.
I was hoping to get a few different types -- I think there are at least 2 different hinges...  fire away.. still have my email?
Quote from: ducatiz on January 25, 2012, 01:33:19 PM
If I do I don't know where.  Good thing I'm not a lawyer.  I will take the photos tomorrow.
kittay
So if I have a 620 with a metal tank and an s2r1k with a plastic would it be possible to swap the tank for tank?
I know something was mentioned about having a pressure regulator, was this already included in the metal tank bikes?
I am really wanting to do this swap, I just don't want to get in over my head or mess something up. I was mostly worried about fuel delivery issues if the pumps had different outputs.
Quote from: kittay on June 13, 2012, 12:05:04 PM
The steel tanks used an external pressure regulator.
If you put the tank from the 620 on the S2R you'd need to add one.
kittay
Ok, do you know where I can find one? I know the tank will be better, but will the fuel pump be sufficient with the FPR?
The old style pump will be sufficient.
I'd check ebay or you can buy one from a dealer.
