November 26, 2024, 04:28:54 AM
Tank Leaking problem....PLEASE ADVICE
Topic: Tank Leaking problem....PLEASE ADVICE (Read 4569 times)
MonsterInDark
Engine roaring....Wind Blasting....memory making....
Riding is a passion....not a commute.....
January 20, 2012, 10:27:38 AM »
Has anyone had issues with their tank slowly leaking? I researched online and people have said that there is a flange leak problem on some of the tanks after u lay down the bike or if you lift the tank full of gas too often...i think this is my problem....but i just got done repairing everything and repainting the bike after my crash
is there anyone who has encountered this problem that had a cheap and easy fix for it...?
Btw its a carbureted 2001 M750 dark
I was thinking of using a tank fixer epoxy putty or something along those lines...any input would be appreciated...
Each day lived is one we will never get back....
Each day lived may be your last....
Ride Hard...Ride Free...Live in the moment...
It could be your last...
Re: Tank Leaking problem....PLEASE ADVICE
January 20, 2012, 11:26:33 AM »
It's leaking from the hinge.
You should have weld/braze reinforced the hinge before painting and coated.
You can try to epoxy reinforce around the hinge and coat, but I've only had that work once.
Perhaps the Caswell coating left thick with epoxy reinforcing outside.
Good luck
atomic410
steel horse i ride
January 20, 2012, 02:29:36 PM »
Hate to sound like debbie downer but you're prob f@@ked. I had this happen to my race bike and learned the weld before you crash lesson the hard way. I tried the epoxy way and it never really worked. problem is once it bends it weakens the hinge area so much that its really hard to get a good sealing weld in there now. plastic tanks ftw
Team Atomic Racing Check us out @
www.teamatomicracing.com
Thanks to my 2011 sponsors;
Motorex, Vortex Racing, Sidi Racing, Studio 299, Dunlop, Motoprimo, Caztek, On Track 4 Him, Fix Studio
2009 Framstad Cup winner
2009, 10, & 11 CRA 5 hour endurance race winner
CRA Expert #2
ZARS track school instructor
January 20, 2012, 03:41:49 PM »
The tank can be brazed in the hinge area (likely where it's leaking) without damaging paint that can be seen with the seat on.
Then the inside coated with POR15.
It's the standard repair for the steel tanks.
January 20, 2012, 03:45:50 PM »
Quote from: Speeddog on January 20, 2012, 03:41:49 PM
True...
but the paint will burn. Recoat stuff usually gets kind of messy.
MonsterInDark
January 20, 2012, 03:54:59 PM »
lol....well luckily for me i didnt paint the underside of the tank so thats not an issue
and speeddog how exactly does one go about brazing something? haha...and if you could PM me with how much you would charge if you do this kinda thing that would be great too!
muskrat
January 20, 2012, 04:33:09 PM »
and don't use JB weld. When I did it that way it lasted about 5 months and went to shit. Get it done right.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
January 20, 2012, 04:45:04 PM »
Quote from: MonsterInDark on January 20, 2012, 03:54:59 PM
we're not talking the underside....
it won't show with the seat in place.
Scooter-Trash
January 20, 2012, 08:39:33 PM »
Quote from: atomic410 on January 20, 2012, 02:29:36 PM
plastic tanks ftw
You may be the first person in the history of the board to say this
Mine's been braised once already and it's leaking again, so my only option is to re-braise and then do the tank treatment?
Ugh.
January 21, 2012, 08:04:06 AM »
Quote from: Drunken Monkey on January 20, 2012, 08:39:33 PM
Ugh.
Was it coated when it was brazed?
It should be coated as the weld/braze is a reinforcement. The coating seals the leak.
atomic410
steel horse i ride
January 23, 2012, 07:34:21 AM »
I just said it to light a fire.
although for the application of a race bike that you'd care less about paint wavyness etc, its the way to go. they do crash well[bacon]
CRA Expert #2
MonsterInDark
January 23, 2012, 09:30:13 AM »
Well i tried the an epoxy putty that is formulated for gas tanks so the gasoline wont erode it as well as a JB weld coating over that....im hoping that it will solve the problem for a little while until i can get up funds down the road to buy a replacement....ive decided that i will jut keep this one and fix it as necessary and then ill order the plastic race tank from CA cycleworks for my bike....and the tank is super sporty and looks alot like a a street fighter tank....so ill just have to buy the red ducati decals so i can keep my Ducati Rep up! haha so now i just have to make it a few months until i can save up the 500$ that the race tank will set me back lol....
January 23, 2012, 12:49:17 PM »
+1
Get it repaired properly. Mine leaked on my balls and near the rear exhaust, think about the potential consequences of that..
Had mine carefully repaired and reinforced in that area. Then this black goo was applied to the area which is a back up sealant. It is impervious to fuel, metho, kero, turps, etc. It is used to bond carbon fiber NASCAR bodywork and is an excellent sealant.
Then I only needed to do some touch up painting of the area hidden by the seat. There's no certainty on the paint risk, but the guy I use can make a tank from scratch, so he's exceptional.
Last Edit: January 23, 2012, 12:56:12 PM by koko64
H-2 CHARLIE
May 07, 2012, 11:41:01 AM »
HEY GUYS , my tank has the same leak 2001 SS steel tank up under the hinge area ... Do i dry the tank out with a air mover fan and run the pump dry before i braze it ? ..#2 And must i use pour -15 too ? ...#3 MUST THE PUMP be removed from inside to do the braze job ?
Last Edit: May 07, 2012, 12:45:40 PM by H-2 CHARLIE
H-2 CHARLIE
Reply #14 on:
May 07, 2012, 12:47:21 PM »
wow , post was taken down ?
