February 22, 2025, 03:24:15 AM *
Author Topic: M796 Custom Tail Chop  (Read 1501 times)
cyberswine
I Just Washed and Waxed my
2011 796 ABS
« on: January 24, 2012, 11:13:24 AM »
I wasn't too sure about a full fender elimination so I've done a custom semi-tail chop.  Because I prefer more visible bling at the back rather that less, I used a Radiantz LED plate holder, looks like this............
And for the purists out there, no thank you, I don't want to ride a Goldwing  Wink
"Life ain't no box of chocklits when you is born a idiot"
Forrest Gump
teddy037.3
« Reply #1 on: January 25, 2012, 11:00:03 AM »
goldwing?
 Huh?
with the plate sitting vertical like that, are there any concerns over the rear tire hitting it?
cyberswine
2011 796 ABS
« Reply #2 on: January 25, 2012, 09:52:09 PM »
Gak! Thanks for raising the question.  The bottom of the licence plate is exactly 2 1/2" lower than the lowest point of the ABS fender.  At the time I thought that was OK, now I'm having serious doubts.  Can't find any info on suspension travel,  I weigh about 180 with gear on, any one have any thoughts on that 2 1/2" reduction in clearance causing a serious problem?
The pictures were taken with the bike on the rear stand so there is some compression showing already.
Forrest Gump
Duc796canada
My first Ducati and road bike!
« Reply #3 on: January 25, 2012, 10:05:45 PM »
Almost exactly look to my bike, minus the tail chop. I was wondering, for the techspec grip pads, did you have to clean the a rear with say alcohol? I have mine awaiting application Smiley
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
cyberswine
2011 796 ABS
« Reply #4 on: January 25, 2012, 11:35:23 PM »
They are Techspecs and yes, the instructions tell you to wash off with either alcohol or a similar type cleanser before attaching them.  I used glass cleaner, worked fine, use a heat gun on low or a hair dryer if it's cold though.
Forrest Gump
teddy037.3
« Reply #5 on: January 26, 2012, 08:55:25 AM »
specs on ducati's site say 5.8" of rear wheel travel... how this may apply, i'm not sure. hmmm... you could do a shakedown ride over some bumps and such to see if it'll hit.
I do recall in the past seeing some tail chops that ended up chewing plates, and my first "I can mount a sticker plate here" idea that chipped the paint from my fender under hard braking
