January 10, 2025, 02:34:49 PM *
Pages: 1 2 3 [4] 5 6 ... 20   Go Down
Author Topic: POLL: Would you buy an aluminum tank...?  (Read 95947 times)
The Bearded Duc
a.k.a. duc750
« Reply #45 on: January 28, 2012, 05:31:21 PM »
when I fill mine up .,.. that's running on fumes, it takes only 2.6gl ...2005 M620D ... plastic tank, my buddy, S4R, S4, 4.4gl also from the fumes ...
That seems a little weird and quite a bit off. Has your tank expanded a lot?
At 2.6 gallons you would only be getting around 80 +/- miles to the tank...
http://www.bikez.com/motorcycles/ducati_monster_620_dark_2005.php
http://www.motorcycle.com/specs/ducati/standard/2005/monster/620-dark.html
http://www.motorbikespecifications.com/2005-ducati-monster-620-dark-technical-specifications
2001 M750 - Sold
Enjoying the ride
« Reply #46 on: January 28, 2012, 06:13:29 PM »
I can read, no expansion, since new, filled just above the white thing inside the tank, 2.5gl and yes about 80kms not miles to the gallon ... max range is 180kms ...
« Reply #47 on: January 28, 2012, 06:36:19 PM »
does Panama use imperial or US gallons?
Enjoying the ride
« Reply #48 on: January 28, 2012, 06:36:50 PM »
US ...
« Reply #49 on: January 28, 2012, 06:46:58 PM »
i bet something is off with your fuel pump.
Enjoying the ride
« Reply #50 on: January 28, 2012, 06:56:17 PM »
telling you, let it run dry and it took 2.6gl ... when I repainted the tank, and refilled it, it took 2.6gl ... my buddies S4/R they have metal tank and fill up from bone dry 4.4gl
« Reply #51 on: January 28, 2012, 07:04:21 PM »
that model has a 3+/- reserve capacity and you must subtract about 0.5L for the pump assembly.
14L - 3.5L = 11.5L = ~3 gal ...  not sure what could be going on there.  but not really relevant to the thread.
the aluminum tanks will likely hold more fuel, no idea how much.
Enjoying the ride
« Reply #52 on: January 28, 2012, 07:05:42 PM »
I was just making a comment and sort of 'threadjacked' ...
btw, installed the rotors ... they good, for now ..
The Bearded Duc
a.k.a. duc750
« Reply #53 on: January 28, 2012, 07:10:34 PM »
Partly my fault on the threadjack, sorry.
Looking forward to the progress on the aluminum tanks ducatiz. And, again, keep me in mind for help with the development if need be. Anything to help get this off the ground!  waytogo
2001 M750 - Sold
Enjoying the ride
« Reply #54 on: January 28, 2012, 07:12:08 PM »
imagine I was willing to purchase a used tank on ebay and send it to a guy in India to have him make it in metal ...
by his FB page he makes good work
« Reply #55 on: January 28, 2012, 07:15:36 PM »
I have about 8k miles on mine, zero issues.
Enjoying the ride
« Reply #56 on: January 28, 2012, 07:16:59 PM »
8miles before battery died ...
Bill in OKC
S4Rs
« Reply #57 on: January 28, 2012, 07:20:30 PM »
I've got an S2R tank on my S4Rs.  With the proper motivation it can be done.
« Reply #58 on: January 28, 2012, 07:31:48 PM »
PM sent
jwoconnor
« Reply #59 on: January 29, 2012, 06:03:52 PM »
I'll PM you as well.  Literally I was saving up for a Beater tank this spring, despite all my whining about the S2R tank. . . .
I knew it!
And I'm in iz.
2007 BMW R1200GS Adventure
Pages: 1 2 3 [4] 5 6 ... 20   Go Up
