January 10, 2025, 05:05:25 PM
POLL: Would you buy an aluminum tank...?
5
6
7
8
20
Topic: POLL: Would you buy an aluminum tank...? (Read 96038 times)
S2R 800 '07
Re: POLL: Would you buy an aluminum tank...?
Reply #75 on:
February 03, 2012, 09:01:57 AM »
oh yesss
another couple of hundred dollars just for that (stock cap though)
Reply #76 on:
February 03, 2012, 11:52:56 AM »
Get me one of those tanks and I'll copy it
Reply #77 on:
February 03, 2012, 12:10:05 PM »
Quote from: ducatiz on February 03, 2012, 11:52:56 AM
I figured we would simply mark up the stock one with a sharpie before it ships out to the fabricator.
Reply #78 on:
February 03, 2012, 12:12:39 PM »
Not as easy as that, it's far more tricky. Esp with the stock fuel pump setup.
Novelo
Reply #79 on:
February 03, 2012, 01:03:37 PM »
I know I'm not contributing here but this made me laugh so hard lol
Quote from: ducatiz on January 27, 2012, 08:16:08 AM
Thanks for reading my original post carefully...
Reply #80 on:
February 03, 2012, 01:28:04 PM »
If anyone is curious..
A 1 inch cube of 4130 steel alloy weighs 0.282 lbs.
A 1 inch cube of 5052 Aluminum alloy weighs 0.097 lbs
Assuming the same wall thickness, the tank would weight a LOT less, however, I am sure they have to make it thicker by at least 50-75% for durability. Even if they doubles the thickness (and therefore the weight) it would still come in at only 2/3rd the weight of the steel.
The Bearded Duc
a.k.a. duc750
Reply #81 on:
February 03, 2012, 01:43:34 PM »
Quote from: ducatiz on February 03, 2012, 01:28:04 PM
This is sounding better and better the further along it gets!
2001 M750 - Sold
scduc
Reply #82 on:
February 04, 2012, 06:13:52 AM »
What kind of time frame are you looking at to get prototypes done?
08' S2R 1K That was close damn near lost a $400 hand cart.
TAftonomos
is without a monster :(
Reply #83 on:
February 04, 2012, 09:37:11 AM »
This makes keeping the s4r that much EASIER
MyDucParts.com
Reply #84 on:
February 04, 2012, 01:08:24 PM »
Thanks to BIll in OKC, I have an S4RS tank to work with.
I'll be fitting it to an S4 and S4r to check clearances, unless anyone has something to add -- have you put an S4RS tank onto one of those?
If all fits, I'll have a tank that fits all the 4v monsters.
The Bearded Duc
a.k.a. duc750
Reply #85 on:
February 04, 2012, 01:12:54 PM »
Quote from: ducatiz on February 04, 2012, 01:08:24 PM
This will make a lot of people happy if it works!
2001 M750 - Sold
Enjoying the ride
Reply #86 on:
February 04, 2012, 03:11:19 PM »
ducatiz,
but, will the 2V pump/mounting flange be "re-usable" or will the desing go the 4V way?
Reply #87 on:
February 04, 2012, 03:50:07 PM »
Quote from: Panamanian Monster on February 04, 2012, 03:11:19 PM
ducatiz,
the 2v design will use the S2R style flange. For S2r bikes, you'll just reuse the same pump setup.
For other bikes, there will be a flange offered which either mounts the internal fuel pump (for FI models) or spigots for the external (carbed) models.
i'm checking clearance tomorrow for a carbed bike with the S2R tank.
Enjoying the ride
Reply #88 on:
February 04, 2012, 03:51:16 PM »
Quote from: ducatiz on February 04, 2012, 03:50:07 PM
so it is different that as for the M620?
Reply #89 on:
February 04, 2012, 04:16:11 PM »
Quote from: Panamanian Monster on February 04, 2012, 03:51:16 PM
M620 is a efi bike. you'll be able to re-use your pump, but you'll put it in from the bottom instead of the top.
5
6
7
8
20
