12K service how much and where?
Started by SaltLick, June 23, 2008, 05:09:59 AM
SaltLick
12k service,
How much does it usually cost and what the hell do they do for the money?
Im about on 9K miles now, i probably need to start saving up.
NEIKOS
Too much.  :o
I'd check out Cheshire if I were you.  I hear lots of good things about their work and Deric was very helpful and informative when I talked to him about getting some work done.
I did my own 12K.  It wasn't cheap - had to buy tools - and it took me forever becuase I'm not mechanically inclined.  It hasn't blown up yet so I think I did OK.  ;)
SaltLick
Quote from: NEIKOS on June 23, 2008, 06:05:26 AM
Too much.  :o
I can do some things, what is included?? I guess i will call cheshire and find out.
NEIKOS
Belt change, valve check/adjust - that's the "fun" part, ummm . . . that's all I remember.
Bendy
12k involves all lube and filter actions (change crankcase oil, fork oil, chassis lube, air filter, fuel filter), replace cam belts, spark plugs and possibly the chain if it's a stretched-out grandmother. I think a complete 12k would be pretty in-depth if it were professional. Dunno if it's necessary to tear the bike down, but personally I'd consider a change of brake and clutch fluid, a good look at brake pads and rotors, check play in the steer head and axles, check valve lash, battery electrolyte, frame/chassis for any cracks, and make sure all nuts and bolts are still on the bike and tight. My theory is, for the cost of a service bill, even if you have to buy tools, anything is worth learning how to do on your own if you ever have to do it more than once. There's a lot of merit in letting an experienced third party do the work if they were to catch a potential safety issue, or if something you check actually does need to be replaced/repaired, but that can go both ways depending on their enthusiasm or carelessness. The owner is probably the most inclined to care the most. I know I am.
krolik
I just had an 18K service done by Cheshire Motorsports.
The total was $758.56, but I had the timing belts changed, and a set of new tires installed/ballanced ($80).
The price for parts was the same as MotoCorsa, and labor was cheaper.  He did an excellent job on the service, he even fixd things I didn't tell him about.
When I had my 12K done at MotoCorsa, it was around $1200, but I had them install a 520 chain and new sprockets.
At both places I've had great service, and I wouldn't hesitate to recomend either one.
desmosome
A lot of the service is premature you can prolly push it a few thousand.
I'd call the shop and find out how much to save as service price has changed.
But I guess from 500 to 1000 dollars.
Do the valve job if you are at red line a lot.
12 or 18k is a good time to have them "set" after that they usually stay pretty good.
Change the belts.
Check your chain and sprockets.
Change Air,Oil,Fuel filters.
Check/replace your bearings, headset, wheels.
Change Oil and hydraulic fluid.
Change park plugs.
Synchronize throttle bodies.
I blew my clutch out at ~15k but that is me
Most of it you can do yourself... and the shop is a good place to go if you don't feel comfortable doing it (or have time).
Doctor Woodrow
Quote from: desmosome on June 23, 2008, 10:45:53 AM
Change the belts.
Change park plugs.
Yeah, I have been having trouble with my PARK plugs too. The bike doesn't seem to want to go into park; no matter what I do to it I can only find 1-6 and neutral.
The Doc
2005 620 Dark "Zerafina", High mount Termi's, Cyclecat rearsets and clipons. Axio "Repsol" Hardpack backpack. Some of us put the 'Damn' in Crash Damnage.
ryandalling
Don't forget to recharge the flux capacitor.
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
trenner
desmosome
They got all sorts of goodies on that site!
      Cross Drilled Brake Lines, Engine Oil Bypass Kit, and Passenger Noise Reducer
[laugh] [laugh]
ryandalling
I just had Julie's Ninja 250 tuned up, valves, carbs, oil with filter, and all adjusted for like $250 at SDS Performance in Lake Oswego... close to Bridgeport.... they did a really good job on it. Rides like a... uh... 250 now....  Still has no real balls... but is fun to ride.
We getting a "Where should I get my bike serviced?" locked thread for stuff like this??
They also setup race bikes, for all you racing peeps.
ryandalling
Hey guys.... I forgot... I have a coupon for SDS.... it's for 30% off labor.... pretty good deal. But it is only good till Sept 1st. Let me know if any of you want it. I think it brings their labor from $85 to like $60.
