February 22, 2025, 11:22:41 AM
Please Help
Alternator cover - timing inspection cover question
Topic: Alternator cover - timing inspection cover question (Read 1269 times)
metroplex
February 02, 2012, 03:49:13 AM »
Is this inspection cover prone to cracking? If so, what are some common fixes? I just heard this from a vendor after inquiring about a case saver for the alternator cover.
These aren't the droids you're looking for
metroplex
Re: Alternator cover - timing inspection cover question
February 02, 2012, 06:53:32 AM »
Do you see any merit in installing a case saver for the wet clutch cover in your 15 years of riding the M900?
February 03, 2012, 12:10:37 PM »
some race series require them
metroplex
February 03, 2012, 12:39:21 PM »
The OEM replacement wet clutch cover and alternator cover is just under $700 each. Every other make of motorcycle refers to these as case savers, it seems only Ducati refers to something else when the term case saver is used.
metroplex
February 03, 2012, 03:45:26 PM »
The 696 has a wet clutch, so the cover is actually the crankcase cover. Do you think an additional clutch cover is warranted?
February 03, 2012, 04:29:04 PM »
If you throw it down really hard, it can crack the cover.
It's not very common though, I've seen lots more rashed up covers than cracked ones.
February 03, 2012, 10:32:13 PM »
You can get the mag ducati cover for close to the same as the stock
