7k on a m620 clutch slipping?
Started by darksideducati, February 05, 2012, 10:34:47 PM
darksideducati
Hello newbie to the motorcycle world I recently changed the oil in my 2005 620 and now the clutch is slipping. I used automotive mobil 1 15w50 and I have been riding in Washington state in our 40-50 degree weather. I did change my handle bars and levers this winter as well. Should I try the oil change first and if so what to use? The bike only has 7k on it I'm the second owner and I bought it last July not sure what was used before
Thanks
Mike
The Bearded Duc
Try this...
http://www.ducatimonsterforum.org/index.php?topic=47487.0
It seems that the automotive oil may have soething to do with the clutch slippage. Try changing the oil, using moto specific oil, and see if the slipping persists.
2001 M750 - Sold
Do you have some freeplay at your lever?
If the lever is mounted and/or adjusted wrong, it can cause slipping.
Both these.  You want .1-.15 mm. free play.
Curmudgeon
Many non-motorcycle oils have friction modifiers, so NG for wet clutches. If you want to stick with Mobil 1, use 4T 10W40 Racing or 20W50 V-Twin which do not.
Quote from: darksideducati on February 05, 2012, 10:34:47 PM
That may well be the source of your troubles. As Curmudgeon noted, there's moto specific oils for a reason. If you've got a dry clutch you could get away with the auto oil swap. But not so much on a wet clutch
darksideducati
Well I have changed the oil two times and continue to run into slipping intermittently. So do I know need to remove the clutch and clean and dry each disc?
