Rizoma billet grip - Left side pinch screw
Started by seanster, February 07, 2012, 09:03:04 AM
seanster
as the title said...do you know the size of the screw?
my grip missing that screw often times i found my hand twisting it, not much but just alittle.
thanks for comment
NateNewThread
a set screw shouldn't be difficult to find
in the meantime you could drill a little hole in the handle bar for the one set screw to recess into and keep it from spinning. don't drill through the handlebar, but just make a little divit. I imagine there is already a marring mark on the bar from all the rotating to use as your guide mark. Just remove the Rizoma grip and drill.
seanster
I was thinking about the same thing while I was riding today.
thanks for the advise.
asherrick
I found a replacement at my local hardware store. Then I used Loctite.
'09 M1100s
seanster
Quote from: asherrick on March 03, 2012, 05:36:07 AM
Do you know the size btw?
asherrick
Sorry, I don't recall. I took the bolt from my other grip with me to match up.
'09 M1100s
