February 22, 2025, 11:09:57 AM
Please Help
How to shorten front trurn signals?
Topic: How to shorten front trurn signals? (Read 2458 times)
Fireman1291
Firefighter/EMT
February 09, 2012, 06:13:08 PM »
So I can't find a thread that shows a how-to
How are you all shortening the turn signals? Do you have to take the headlight apart to reach the bolt? Is there a write up out there? Any help is very much appreciated.
2012 Monster 1100EVO Black/grey
wannabfast
Re: How to shorten front trurn signals?
February 09, 2012, 09:50:17 PM »
yup headlight has to come out, and those bolts holding them in need to be replaced with shorter ones when you pull the spacer out
February 09, 2012, 10:15:07 PM »
BUT.... it's a really simple process.
Full_Spectrum
February 10, 2012, 08:10:21 AM »
Quote from: wannabfast on February 09, 2012, 09:50:17 PM
This should take no more than 30 minutes to do. As noted, you will need to replace the mounting bolts which I think are 6mm allen head.
Fireman1291
Firefighter/EMT
February 10, 2012, 03:41:07 PM »
Thanks guys! Anyone know the thread pitch or can you point me to a place that sells the correct length? Thanks again!
Ill do the silverstar bulbs at the same time. High and low beam are both H7 correct?
DucNaked
February 10, 2012, 04:39:40 PM »
Quote from: Fireman1291 on February 10, 2012, 03:41:07 PM
I just took my old ones to the local hardware store and got the correct size I needed. It cost less than a buck for the new ones.
wannabfast
February 15, 2012, 08:04:27 AM »
low beam is h7, high beam is h1
craig697
February 15, 2012, 12:17:42 PM »
Hey, I used m5-25mm hex head easy to find a any auto parts store.
07 s2r1k
10 696
wannabfast
February 15, 2012, 07:04:57 PM »
Quote from: craig697 on February 15, 2012, 12:17:42 PM
you sure it was 25? i just picked up a 20mm long bolt, and its way too long, i think it needs to be a 15mm long bolt
craig697
February 16, 2012, 12:17:22 PM »
Sorry, just checked bought 25mm they were to long used extra hex heads from when I did the fender eliminator 10 or 15mm. They were part of the stock fender mounting bolts.
07 s2r1k
10 696
