'94 M900 - Tank Vent Hoses
Started by Howley, February 10, 2012, 04:28:22 AM
Howley
Hi All,
I have two vents coming out the bottom of the tank on my '94 M900.
I'm guessing one is overflow and one is a vent, so I'm guessing I can splice the overflow into the carb overflow, and leave the vent alone. Is this true?
Am I able to splice these both into a single hose?
Thanks!
Luke
If you have no charcoal canister you van use a Y connector and splice them together.
Howley
Excellent. And I can splice them into the carb overflow?
battlecry
If you do, it may complicate removing or lifting the tank.
tank overflow is non-pressurized
putting it onto the carb return will pressurize it in the wrong direction.
the vent hose should just hang loose.
I took the charcoal canister off (Howley is in Oz right?  No canister there) and ran both below the bike.
Howley
Which is the vent and which is the overflow?
Quote from: Howley on February 10, 2012, 07:43:32 AM
Usually there is a sticker on the bottom of the tank showing the orientation.  I don't have that bike so i can't tell, but usually the one nearest the rear is the vapor line and the one towards the front is the overflow.
Pretty sure the overflow/cap area drain is the one closest to the outside of the tank.
Nomad
I'm not recommending this, but now I'm curious.  In the process of putting in my FCR's, I for some reason removed both those hoses.  I haven't experienced any ill effects, am I just lucky or is it not a big deal?
Quote from: Nomad on February 10, 2012, 10:00:59 PM
The job of the hoses is to keep fuel from dumping on your engine if you spill while fueling or fuel comes out of the vent hose from expansion.  No overfolw or expansion, no problem, but...
Nomad
Quote from: howie on February 10, 2012, 10:05:37 PM
Gotcha, I'll be careful and not top it off completely... or find some hoses that fit
Howley
Correct howie and ducatiz.. I blew into the outer-most outlet, air came out the overflow drain.
Real Recognize Real
Quote from: Nomad on February 10, 2012, 10:25:21 PM
This is my scenario (FCRs and removed hoses) but I'm going to reinstall the vent and overflow hoses. Btw - what size are these hoses?
Don't argue with idiots. They'll drag you down to their level and beat you with experience.
6mm i think, but you better just check.
Howley
