Anyone have a integrated tail light plus led turn signals?
Started by K3V1N, February 10, 2012, 06:44:06 AM
Work in what regard?
I've had two, both worked. The current better than the past.. but it's not any sort of techno-wizardry. It's just a different placement of the light.
It will work fine, but I have an idea....
If your integrated turn signal light is the sequential type - how about soldering a lead from the outer LEDs to the new outside lights? The turning signal sequence will start from closest to the center and finish with a signal in your new light...
K3V1N
That is a good idea! hmmmm
I also might just not use the sequential part of the tail light. I will mess with it this weekend and report back.
Thanks for the replies.
Two dogs
+1 ^ An easy mod did it on mine ,just stripped the wire back with a blade soldered in the indicator wire and finnished with heat shrink  [thumbsup] , and it really improves visability also keeps the  [leo] happier
down here as the esquential on its own is not legal.
118811
Quote from: Two dogs on February 10, 2012, 02:52:35 PM
+1
Great mod & easy, with good visibility
Keeps the  [leo] happy too
K3V1N
After messing with my options. I ended just disconnecting the turn signal wires to the tail light and running those wires to the turn signals. All I really had to solder 2 ground lines from the ground to the tail and add connectors. So the tail light does it's blink and stop only.
I went with the Barracuda SILUR e-marked LED Aluminum Turn Indicators the quality looked a little better in the photo but they're very bright.
Next I'm thinking of some stripe of 6 tiny leds to stick on my plate to give the bike a little more stopping light.
Then my tail chop clean up will be complete. Thanks again for your feedback.
