suddenly not starting... DIAGNOSED!
Started by Howley, February 11, 2012, 04:15:31 AM
Howley
So I did some work on the tank this morning and after getting it back together, I tried to start it. It cranked over, but the it was slowing down a bit and I didn't want to kill the battery. That's cool, I wasn't worried just figured it needed time to get the fuel going.
Jump to the afternoon, I came back to try it again as I'd had it on the battery tender a few hours. This time it turned over about twice, then the starter motor just whirred, now it just clicks at the solenoid. What changed in those two hours?
I'm yet to run any tests to work it out. I think its about time I up-rated the cables.
Howley
So I tried it this morning. It is actually turning the motor, but hardly at all. I jumped from the battery directly to the starter and it was exactly the same, which leads me to believe something is up with the starter.
Any suggestions on what could cause the starter to suddenly pack it in?
corey
not sure how old the bike is, but maybe age? wear and tear?
Thermite
'07 S4RS and '04 998 Matrix.  Because sometimes I feel like a monster, and sometimes I don't.
Howley
Yeah sorry. It's a '94 M900. Battery is probably 2.5 years old, not much use out of it in that time. I read 12.5V across the terminals with the engine off.
Testing the starter with the same battery doesn't really prove anything other than your connections  probably are OK.
Do you have access to another known good battery you can test the starter with?
Howley
Yeah I was thinking the same. I'll have to try it with my car battery.
corey
94 was what, 18 years ago? might be time to grab a new starter even if this one isn't entirely dead, rather than get stranded when it DOES go, right?
Howley
I might end up doing that. What bikes have compatible starters? Is guess any 2v prior to the 696?
Quote from: Howley on February 12, 2012, 02:27:16 PM
AFAIK, starters were pretty much the same for a long while, up until the (I think) 1100 when ratios changed.
But, need more confirmation.
Quote from: Speeddog on February 12, 2012, 06:03:33 PM
I think you're right.
I think the only difference is the drive gear.
Real Recognize Real
I have a '94 M900 and had to replace my starter last year. If you decide to go this route, check out this vendor:
http://www.stockers.com/index.php?dt=DS-101N
I ordered from them and it was the best price I found - I'm not affiliated with them at all.
GL
Don't argue with idiots. They'll drag you down to their level and beat you with experience.
Howley
Howley
Update. I tried it out with my car battery and it was exactly the same. Time to pull the starter motor by the looks of it. It's a pin in the ass because I need to do the stator coil too, but I can't bloody find one.
