April 28, 2024, 09:42:53 PM
DFWM
Need the resident suspension setup guru
Topic: Need the resident suspension setup guru (Read 2332 times)
billy9304
June 23, 2008, 01:19:00 PM »
Need some help setting up the suspension on my new ride. I am most definitely the anti suspension guru, however I do pay handsomely in beverages of your choice
Any takers?
♣ McKraut ♣
touched by his noodly appendage
Re: Need the resident suspension setup guru
June 23, 2008, 01:23:37 PM »
Quote from: billy9304 on June 23, 2008, 01:19:00 PM
Any takers?
i could contribute to the pool of beverages as well for help with the setup on the SS...
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
bryant8
2008 848 White
June 23, 2008, 01:27:40 PM »
Make that three! Although I'll probably just bite the bullet and take it in to AMS
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
RichD
June 23, 2008, 01:59:34 PM »
Come on guys! ...setting up for the street is not ALL THAT!
1st, TIRE PRESSURE, get the right springs, set sag,
and go to work...
It's not that hard,
...and what any tuner tweaks it to just works for him, not necessarily YOU.
If your trying to set track records, that is another thing...
DFW-MFer!
fastwin
June 23, 2008, 02:12:22 PM »
You set it up? It has settings?
ddjones
June 23, 2008, 02:14:40 PM »
Any takers?
I could use some extra hands to set my spring sag but I live about as far east of Dallas as you do west. Maybe a sag party someplace in between?
bryant8
2008 848 White
June 23, 2008, 02:16:59 PM »
Quote from: CountPuggula on June 23, 2008, 01:59:34 PM
and go to work...
It's not that hard,
Next I'm time in Arlington, if you're available I'll be dropping by for some help then
Last Edit: June 23, 2008, 02:19:38 PM by bryant8
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
RichD
June 23, 2008, 03:49:04 PM »
From Ohlins, here is the recommendations on sag:
Without rider (static sag):
Rear: 10-20 mm (R1-R2)
Front: 15-30 mm (F1-F2)
With rider (ride height):
Rear: 25-40 mm (R1-R3)
Front: 35-50 mm (F1-F3)
...that range is "full tilt boogie"-track to "cruiser".
I run rear (ride hight) 30mm, front 40mm.
If your springs are right -your static sag should be in the ballpark above (about 15mm/20mm +/-)
Without the sag being set first, you are wasting your time with anything else.
(okay, you should have your tire pressure right too)
All it takes is a ziptie (for the front) and a piece of string (for the rear),
...and a buddy to measure it while you are on the bike and a few tools.
Then you can get to clicking the adjusters.
Only once you play with it will you know what you have.
On a quiet road run the adjusters full soft. See what it means.
Then run them full in, see what that means.
Drop the nose of the bike (raise the forks in the clamps) and it will dive into turns.
Go too far it will be unstable/twitchy.
Raise the rear it will do the same -but transition quicker -and "stoppie" more too...
Find
your
happy spot...
If you like to turn screws you'll mess with it forever like a carburetor!
DFW-MFer!
svoloch
too old to remember my titanium member...
June 23, 2008, 04:10:36 PM »
The general rule is that the less adjustable your suspension is, the more time you will spend riding
Тише едешь, дальше будешь
2009 Streetfighter S
exes:
2006 Sh1t Hot Black Xerox 999 1973 BMW R75/5
2001 BMW K1200RS 1994 BMW R1100S
1974 Guzzi T3 1975 BMW R90/6
1975 BMW R90/S 1973 Suzuki T500
RichD
June 23, 2008, 04:30:13 PM »
Quote from: The Svoloch on June 23, 2008, 04:10:36 PM
There is some truth to that!
-But then there are days when I hit the road with a bag of tools just TO adjust it! [moto]
DFW-MFer!
cdc
my superbike. nutts someone copied my avatar.
June 23, 2008, 07:15:28 PM »
Any takers?
Hey Billy,
If you are near the SW Fort Worth area, you can come to the house and we can tinker with it. I'm not a guru but for sure we won't mess things up. As already mention, the first thing is to dial all your rebound and compression settings to stock then set your sag. Once that is set, the rest of the settings is up to your preference with some guidance from what has been written and is available information.
I'm sure we can get a bunch of peeps to come and stand around telling us what to do while drinking beer. We really just need a few more hands to lift the bike and write down numbers but I've seen the front and rear lifted on the side stand. I prefer not to do that but that's one way.
If your willing to tinker with it, I am game to help.
FYI, it is possible that in trying to set your sag, we find that it's not possible. When that happened to me, Jeff at AMS ended up working on the forks only to find out that the fork oil level on one of the forks was low. I ended up having him rebuild the forks on a 3 year old bike and the front is now so much better.
Of course, Randy McCarter can set it up for you as well if you don't want to get your hands dirty and know it's done right.
cdc
fastwin
June 23, 2008, 07:15:54 PM »
I had those tools with me yesterday to play with my newly reborn Ohlins shock and you know what? I never messed with it... I just rode the shit out of my bike and had fun. The more I rode and the faster I went the less I thought about it. Either Dan Kyle worked wonders or I was having too much fun to even think about sag or settings. I guess that's a win-win!
bryant8
2008 848 White
June 24, 2008, 07:24:09 AM »
I started messing with the suspension yesterday based off of the tips that RichD gave, pretty simple so far. I do need to get a Showa shock adjuster though
Last Edit: June 24, 2008, 07:28:44 AM by bryant8
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
bryant8
2008 848 White
June 24, 2008, 07:29:09 AM »
Anybody out there have one I can borrow/steal for a little while?
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
♣ McKraut ♣
Reply #14 on:
June 24, 2008, 07:30:34 AM »
i bet richd can make one
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
