Pressure Plate Newb Question
Started by arai_speed, June 23, 2008, 04:02:56 PM
arai_speed
Hey guys, I recently changed the springs on my Monster and after installing them and taking it out for a spin I noticed that the pressure plate floats freely when the bike is in gear w/the clutch pulled in.
If I release the clutch the pressure plate engages and all is well, shifting and changing gear is fine, I just want's sure if this is normal.
Thanks.
Rameses
When the bike is in gear, the pressure plate is hooked to the rear tire.
The only time it spins is when the rear tire spins.
Quote from: Rameses on June 23, 2008, 04:24:22 PM
or in neutral.
arai_speed
If you start your bike in gear, will the pressure plate spin? Or will it just free float until you disengage the clutch?
it is free floating, so it will stop eventually, you could stick a hand in there and just stop it yourself if you wanted to. It might continue to spin gently too but thats okay, unless your bike feels like its going to stall.
arai_speed
Quote from: He Man on June 23, 2008, 05:07:53 PM
OK - so that's normal.  Like I said, I changed the clutch springs and I didn't remember if the PP behaved that way or not before the change.
Thanks for confirming.
Rameses
#6
Quote from: He Man on June 23, 2008, 04:37:19 PM
or in neutral.
Hence I said "when the bike is in gear."
And no, if you start your bike in gear with the clutch lever pulled the pressure plate won't spin.
Again, if the bike's in gear, the only time the pressure plate spins is when the rear tire spins.
