April 27, 2024, 09:36:08 PM
NorthWest
Inane ramblings to avoid thread jacking
52
53
54
55
272
Topic: Inane ramblings to avoid thread jacking (Read 517508 times)
toolfan
Re: Inane ramblings to avoid thread jacking
Reply #780 on:
December 08, 2008, 02:51:59 PM »
This is my computer background at home:
Quote from: Tailgunner on December 08, 2008, 02:47:55 PM
You ever grab some brake and they fail? It feels like you instantly gain 10 mph. How come?
damn hippies
make the beast with two backs yeah.
I'm still curious about how it went down - or rather, how it didn't go down.
Tailgunner
Reply #781 on:
December 08, 2008, 02:55:36 PM »
Laughing so hard I look like this:
dick
Visolara
Jacobs Love Meat
Reply #782 on:
December 08, 2008, 03:19:09 PM »
I dont lose traction when I modulate the throttle in a lean. Its simply under power, or not.
Maurice Miller
2009 OMRRA Rider Representative
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
Noel Communications, Inc. , 2Fast Motorcycle Track Days & Instruction , KBC Helmets , EDR Performance , Cascade Tracktime , GP Suspension North , KFG Dunlop LLC , LP Privateer , Dainese , AMS Oil
| 2006 Ducati 749S (street) | 2004 Suzuki SV650S (race) | 2002 Aprilia Mille (race) |
toolfan
Reply #783 on:
December 08, 2008, 03:23:59 PM »
Quote from: Visolara on December 08, 2008, 03:19:09 PM
I know, but truly "steering with the rear wheel" requires braking traction - and I'm not there.
Even in racing, I rarely went to 100%, I could always "push more to lean more" to tighten my line, and I never went 100% in a pass. I actually think I ran slower times when I thought I was going 100%...
That's why I'll go down as an "also ran," I suppose.
Visolara
Jacobs Love Meat
Reply #784 on:
December 08, 2008, 03:54:37 PM »
ok, now Im confused. When did backing it in enter this conversation?
Maurice Miller
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
Mother
Reply #785 on:
December 08, 2008, 03:55:11 PM »
I will maintain that teaching clutch in/brakes on technique over brakes on/downshift is lining certain riders up for failure
and I mis-represented my stance on this
i am not proposing Engine Braking as an alternative to brakes
I am proposing that it needs to be used as a filler in between brake application
as far as teaching it solely, you call it complacency, and I call it proper preperation to a stop
when riding on the street you should be aware far enough ahead to downshift a bike to a stop applying both brakes at the 2nd and 1st gear mark
initiate the stop with downshifts
5th-4th-3rd-Rear Brake-2nd-Front Brake-1st/Stop
Rear/Front brake-5th-4th-3rd-2nd-1st/Stop
but never
Clutch-Rear/Front Brake-Stop
you mentioned the front brake is the most importaant aspect of stopping, i agree
and
you mention that the rear brake is more powerful than the engine brake, I agree
but the engine is still a slowing factor and a force to be dealt with when slowing or stopping
you can grab as much front and rear brake as you want but if you also downshift at the same point and hear the motor increase revolution then it is applying drag to your stop which is contributing to the force of slowing
Last Edit: December 08, 2008, 04:13:42 PM by Mother
toolfan
Reply #786 on:
December 08, 2008, 04:06:37 PM »
Quote from: Visolara on December 08, 2008, 03:54:37 PM
Backing it in is only a small part of steering with the throttle... right?
I've decided to drop this portion of my argument. I don't steer with the throttle, and honestly, I only have theory for discussion. It works for you, so I'll concede you are the expert there.
I think one time, someone asked Rossi how he wins so many races, and he said "easy, less brake, more throttle."
In reality, we do things different, but ideally, you'd go smoothly from the brake to the throttle for the fastest way around, right? Use the most powerful tool in your box, most of the time?
Quote from: Mother on December 08, 2008, 03:55:11 PM
I will maintain that teaching clutch in/brakes on technique over brakes on/downshift is a lining certain riders up for failure
You know what the second leading cause of single vehicle motorcycle fatality accidents is (in Oregon)? Not stopping quickly enough.
I will maintain that there is no harm in not teaching engine braking, but there can be harm in relying on it.
Last Edit: December 08, 2008, 04:15:36 PM by toolfan
Mother
Reply #787 on:
December 08, 2008, 04:20:52 PM »
Quote from: toolfan on December 08, 2008, 04:06:37 PM
I am not proposing engine braking over brakes
and
i am not factoring this concept for an emergency stop
the main point I am making here is the idea of removing it from the equation (clutch in) is stupid
toolfan
Reply #788 on:
December 08, 2008, 04:31:42 PM »
Quote from: Mother on December 08, 2008, 04:20:52 PM
and
Trust me, taking it out of the equation works much better.
"All four paws kiddies, both hands squeeze, both feet press."
If you try something else, you'll end up with bodies everywhere*
And to respond to your edit -
I don't let the clutch out between gears when I'm stopping in a remotely quick manner.
IE - coming into T1 at PIR - Brakes, clutch 5-4 clutch out, brakes out
Emergency stop on the road - brakes, clutch 4-3-2-1 (as required)
In a laxidasical stop, I'll shift w/o clutch, or I'll let the clutch out - but this is a complacent stop where I'm not concerned with getting my speed down NOW.
toolfan
Reply #789 on:
December 08, 2008, 04:35:43 PM »
*funny aside...
One time, in a class that I wasn't a part of... a student came in clutch out in the quick stop excersize of a BRT course. This was at the Sylvania course, which has very little run out on one of the stopping chutes.
She panicked a little bit, for one reason or another, and stopped braking and continued throttling. (a common "mistake" for newbs is to roll on the throttle while applying the front brake - another reason to teach them to pull the clutch in.) She overshot the braking chute, and went over the curb and through the shrubbery, and down into a parking lot below. Because she was still upright, she decided to just cruise the parking lot, taking a little tour of the facility, up the driveway, around the range and back in line.
The instructors were, umm... impressed, I suppose.
Mother
Reply #790 on:
December 08, 2008, 04:47:06 PM »
Quote from: toolfan on December 08, 2008, 04:31:42 PM
this is the approach that most instructors use here at the FD as well
they dumb down a concept in order for the lowest common denominator to understand
then when you need to rely on the person taught in this manner they have huge gaps in their understanding of an idea
I don't like that approach
simplify yes, ockham's razor yes, but don't take out the idea completely
as a teacher you are the expert sure but to eliminate a principle in order to teach those likely unteachable is cheating your better students
and yes your better students will find the knowledge on their own
but
take my experience with Team Oregon and that jackass bill or howard or whoever we figured it was
constantly telling me that rolling off and using my rear brake was wrong
well in the lowspeed stuff we were doing it was perfectly acceptable
and I still have my giant front rotors available if I need to stop NOW
I'm not saying that you are a poor teacher
and I understand that you need to keep it simple for the amount of people you teach that really shouldn't be there
but
it pisses me off to have a teacher assume I'm stupid and teach me like I cannot learn a complicated idea
because he/she hasn't taken the time or does not have the time to actually know the student...yes this is left over Dr Phil shit of mine from High school
Last Edit: December 08, 2008, 04:52:07 PM by Mother
Visolara
Jacobs Love Meat
Reply #791 on:
December 08, 2008, 04:49:06 PM »
My contribution to this yell at Elias thread was while in a committed turn (no rear wheel loss of traction here), you can control your lean with the throttle. On throttle pulls the bike up, and increases radius (you do this on exit all the time!), and roll off throttle (even a little), will make the bike dive in (tighten the radius). I use this all the time when racing to correct my line while in a committed lean.
Now stop yelling at me, and start drinking!
Maurice Miller
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
Mother
Reply #792 on:
December 08, 2008, 04:54:22 PM »
it kills me when maurice has these lucid moments
like he knows more than
ooh ooh beer
and
ooh ooh boobies
toolfan
Reply #793 on:
December 08, 2008, 04:56:14 PM »
1) It's not dumbing down - that's how to do a quick stop. Further, for people with little or no experience, it's
borderline
blatantly dangerous to attempt a quick stop with the clutch out. Fully 2/3 or any given class will come down the chute at least once with their engine near redline because they've rolled on the throttle as they've squeezed the brake. With the clutch in, this is just noise, clutch out, this is someone getting hurt and firefighters having to come down and demonstrate their techniques.
2)The excercise is called "Quick Stop."
You were not demostrating a "quick stop." Your instructors did not know you, or your skill level, so they must coach you to demonstrate your proficiency at stopping quickly.
(insert mean spirited joke about running into _____ here)
(insert your choice of raccon, family of raccoons, bridge, Morilla or other in the blank space above.)
Quote from: Mother on December 08, 2008, 04:47:06 PM
then when you need to rely on the persontaught in this manner they have huge gaps in their understanding of an idea
but
but
Mother
Reply #794 on:
December 08, 2008, 05:01:56 PM »
Quote from: toolfan on December 08, 2008, 04:56:14 PM
borderline
hhmm
how to get through to the big educated dummy that I am not talking about engine braking and a quick/emergency/oh shit stop...
I see your bridge comment and raise you a driveway comment
52
53
54
55
272
