Can I take these off?
Started by Skyshadow, February 29, 2012, 12:47:16 PM
Skyshadow
Took off the eye sores yesterday and installed the Factory Pro kit and pod filters. will post up pics later, runs great now! But I have a high idle.
- Homemade Exhaust
- K&N filter
- Tail chop w/ integrated tail light
- Sliders
Quote from: cupcake on February 19, 2012, 04:53:56 PM
My rear brake is just for looks.
brad black
the hoses with springs are the air supply for the choke valves.  the hose going to the lh box is a vent.  you need to make sure the end of the vent is in a dead air area.
Brad The Bike Boy
http://www.bikeboy.org
pslinux
After you get your hoses routed correctly try adjusting the idle speed screw on the front of the carb.  And with those pod filters it will be easy to get to, just do it while the bike is running to set the idle where you want it.
Skyshadow
Hoses are routed to the battery area so it's pretty still air for a naked monster. will attack the idler screw tonight.
- Homemade Exhaust
- K&N filter
- Sliders
