Can I switch out just the cans on the exhaust I have on my bike?
Started by Gadgetech, March 07, 2012, 07:33:58 PM
Gadgetech
Here's a picture of my bike with the aftermarket full exhaust that came on the bike when I picked it up a couple weeks ago.  Would it be possible to replace the cans with something other than the Remus?  There is a spring holding the cans on just above the heel protector on the backside.
seanster
Quote from: Gadgetech on March 07, 2012, 07:33:58 PM
You currently have one of those exhaust with dual cans one on each side.
Those single swingarm came stock with dual exhausts both on the right side.
The headers are different....so depends on which set up you like ...
Anyone correct me if im wrong.
How about a closer pic or two, showing the front of each can and 6" or so of the header that connects to it?
ALL of the header replacements for the S2R lined up so you can use the stock RHS cans, at least all of the ones I've seen:  Sparks, Termi, etc.
Quote from: ducatiz on March 08, 2012, 09:34:32 AM
Yes, but the picture may show that these pipes don't have the "universal" connection points, just under the foot pegs?
scduc
If there is a union where the can and the pipe connect, then there should not be a problem. Most of the setups I've seen however, the can is solid with a section of pipe. If this is the case, then some custom work will need to be done in order to use different cans. Custom work can have many rewards. I've chopped my Sil-Motors and I am quite happy with the look.
Gadgetech
Here are some close ups.
You can see where the pipes connect just above the boot protectors.
Here's a picture from the backside.
This is stock/universal location.
Unless there's another pair of connections, quite different and not interchangable - sorry....
i can't tell the difference from the angles.. looks the same to me...   ???
muskrat
I had the same set up in Termi's on my S2R.  Depending on the mid pipe in use you may or may not use the single sided exhaust.  I personally think you should trim the ends down about 3 to 5 inches to match the frame and vuala.  Here's one of my scavenged S2R exhaust on my S4R shortened.
you could also consider the shorty GP exhaust which was sold by motivation accessories in Austin, TX.  Here's a link to my old S2R being sold with the exhaust.  :'( http://dallas.craigslist.org/dal/mcy/2864176434.html
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Gadgetech
Muskrat, I like that shorty exhaust on your S2R it looks good.
In terms of shortening the exhaust, where on the pipe do you cut?
scduc
It looks like Gadgetech's headers are sitting higher that the stock position. But that does not make any sense. That would mean that those cans only work with those pipes. Which means in order to change just the can, custom work is necessary.
Gadgetech
Guess I'll either deal with the cans that are on there or put a replacement set at the back of my mods list.  I appreciate all the replies.
muskrat
drill the rivets out on the end where the straps are, measure and cut then rivet back on.  Make sure you measure right since you only get one chance to cut.  [thumbsup]
the plus is that they sound better.
2015 MTS 1200
09 Electra Glide
