February 22, 2025, 04:44:25 PM *
Author Topic: Removing Rizoma Bar Ends  (Read 1495 times)
cyberswine
I Just Washed and Waxed my
2011 796 ABS
« on: March 11, 2012, 02:01:48 AM »
When I installed Rizoma bar ends I had to remove the right side to put in a spacer to prevent the tube from binding.  I found that the bolt came out and left the rubber bungy bungy expansion thingy in the bar with the two acorn nuts still inside.  No problem, but now I'm ready to put new bars on and I don't want to lay out the extra $$$s for new bar ends.  Does anyone have any ideas on how to rig  some kind of puller/extractor to get the little buffers out of there?
"Life ain't no box of chocklits when you is born a idiot"
Forrest Gump
S2R 800 '07
« Reply #1 on: March 11, 2012, 02:34:41 AM »
Push from the other end with a semi flexible rod?
teddy037.3
« Reply #2 on: March 11, 2012, 08:13:21 PM »
drill it out?
:edit: n'mind, you want to save it. can you see the internal thread? you could maybe find a longer screw and use that to pull it out if that's the case
« Last Edit: March 11, 2012, 08:15:13 PM by teddy037.3 » Logged
