February 22, 2025, 11:23:11 AM
Noob question - must the brake / clutch fluid reservoirs be mounted high?
Topic: Noob question - must the brake / clutch fluid reservoirs be mounted high? (Read 1111 times)
slowkitty
March 14, 2012, 07:15:44 PM »
Can it be mounted lower than the master cylinders? All pics seem to show high - gravity feed?
Cheers
Feral 859
Re: Noob question - must the brake / clutch fluid reservoirs be mounted high?
March 14, 2012, 07:24:36 PM »
You can get em low
Last Edit: March 15, 2012, 02:54:37 PM by kupcaker
slowkitty
March 14, 2012, 07:48:28 PM »
Thanks, but will there be a problem in feeding the system if mounted lower than the master cylinders? I have always assumed that the fluids are gravity fed.
Nottsbiker
March 15, 2012, 05:24:55 AM »
Looks like the bike in the picture has the levers rotated around the bars to point slightly downwards and the resevoirs are mounted horizontal to the brake cylinder, but are still above it so they are gravity fed.
Ducati Monster 900 (project) Aprilia Tuono 1000
March 15, 2012, 06:19:02 AM »
The reservoirs need to be at least level with the lowest part of the hose or inlet of the master.
Omnipotent Potentate
Personal Pretext
March 15, 2012, 06:21:05 AM »
Quote from: slowkitty on March 14, 2012, 07:15:44 PM
gravity feed?
Yup
zooom
March 15, 2012, 06:34:27 AM »
Quote from: howie on March 15, 2012, 06:19:02 AM
+1 unless you want an air bubble to be in the wrong place at the wrong time....
2010 KTM 990 SM-T
